post #1 of Old 09-29-2009, 08:13 PM Thread Starter
JackStraw
electrical gremlins
my wife's jeep has recently started having some electrical gremlins. the overhead console sometimes doesnt work. the cruise doesnt set, you can turn it on, and the green cruise light comes on, on the dash, but when you press set, it wont set. also, the blend doors for the ac are stuck to only blow from the defrost vents at the windshield. battery is new, battery cable is new. is there a way to reset the electrical system? can the blend doors be moved manually? any help is appreciated, thanks.
1999 Grand Cherokee 4.0
215,000 mi
Bone Stock other than K&N airfilter
JackStraw is offline
post #2 of Old 09-30-2009, 01:47 AM
jeepheller98
the cruise and vents work off of engine vacume. you have a leak. start at the cruise control under the hood. they are on the same vacume line so if one goes out so does the other
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
post #3 of Old 09-30-2009, 08:43 PM Thread Starter
JackStraw
thanks, i'll have to check that out
215,000 mi
Electrical gremlins pcv57 ZJ Grand Cherokee Forum 2 01-28-2010 11:29 AM
Electrical gremlins TPS/IAC Chloetar ZJ Grand Cherokee Forum 3 05-24-2007 08:40 PM
electrical gremlins crexor ZJ Grand Cherokee Forum 0 01-21-2007 02:15 PM
Electrical gremlins Beachy ZJ Grand Cherokee Forum 6 09-10-2006 10:06 PM
Electrical gremlins buzzbomb ZJ Grand Cherokee Forum 9 12-26-2002 12:14 PM
You may not post new threads
You may not post replies
