Electrical gremlins - JeepForum.com
post #1 of 10 Old 12-19-2002, 06:57 PM Thread Starter
buzzbomb
Electrical gremlins
'96 grand cherokee limited, my dash lights went out this evening. They come on intermittantly, and the odometer and radio lights dim when the dash lights come on, then get brighter when the dash goes black. Also, the last few days, the tail lamp failure light has been coming on, but there are not any lights out- are they related problems? Thanks,
buzzbomb is offline
post #2 of 10 Old 12-19-2002, 07:18 PM
gcl97
I had the same the problem with my Honda Civic. After wondering and asking what the problem was, I found out that the dimmer switch of the dashboard was bad. Try a new switch (or one from the junk yard) and see if this resolve the problem. Or, you can check it out with some kind of analyzer. In anycase, I'll start with the dimmer SW. Good luck.
gcl97 is offline
post #3 of 10 Old 12-20-2002, 12:54 AM
ZJGuido
Junior Member
ZJGuido's Avatar
I also had the same problem with the tail light failure warning coming on eventhough all the lights worked. Try cleaning the connections where the bulbs plug in, on all the brake lights and make sure they're in tight, this worked with my problem.
Concerning the odometer and radio lights going dim when the dash lights go on, and viseversa, thats normal, but i wouldnt be able to tell u about the lights going on intermidately
1998 Platinum ZJ 5.9 Limited
K&N FIPK / MOPAR ECU / Bilstein Shocks / H&R springs / Addco sway bars
ZJGuido is offline
post #4 of 10 Old 12-20-2002, 10:27 PM Thread Starter
buzzbomb
Now the tail lights are going out, and the dash lights flicker like christmas lights, maybe it's just that time of year. Anyone know of a ground I should be checking, or a fuse, or something...
buzzbomb is offline
post #5 of 10 Old 12-21-2002, 12:12 PM
madmanfrommars
madmanfrommars's Avatar
I keep loosing those "glow lights" on the car. Anyone know what I'm talking about? That glow on the controls when you put ur headlights on? the green glow?
anyway, the one in my shifter is intermiddent, and one of the ones up with the thermomitor doesn't work very well either.
As far as I know, I'm the only person to own a flame red liberty with the light bar, and until someone disproves that to me, I'm going to enjoy it.
madmanfrommars is offline
post #6 of 10 Old 12-21-2002, 01:00 PM
MJR
MJR's Avatar
1988
Yes I would say you have a bad headlamp/dimmer switch. On the other problem it could be a couple of things. I think you are talking about the "rear lamp failure" or such ?. The first thing I would do is check the third brake light bulbs. It might have 2 or 3 and make sure they are the right ones 921 or 922 on the bulb. If they are blackened at all replace them. This will usually fix it. If not check all your parking light bulbs (front and rear). If this is not it then it might be corrosion in the tail light wiring harness connectors. I would guess it is a bulb though.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #7 of 10 Old 12-23-2002, 05:40 PM Thread Starter
buzzbomb
I replaced the automatic headlight switch, and I still have no tail lights, and dash lights are no longer flickering, just gone. Any other ideas? How does the tail lamp module work?
buzzbomb is offline
post #8 of 10 Old 12-23-2002, 06:00 PM
bulletbob
This sounds more like a solid state module failure than a headlamp switch. Most times when Jeep switches go bad you'll smell them burning.I can check the schematic at work and let you know what is in that circuit . email me if you need help.... bullet_bob@lycos.com..... bob
bulletbob is offline
post #9 of 10 Old 12-25-2002, 05:36 PM
MJR
MJR's Avatar
1988
Check the parking light fuse in the underhood fuse box.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #10 of 10 Old 12-26-2002, 01:14 PM Thread Starter
buzzbomb
I fixed it! The swich was bad, and had also blown the fuse. I had checked the fuse earlier, and it was not blown, this was while the lights were flickering. The fuse blew at some point, then when I replaced the switch, it didn't work. Just checked the fuse, replaced it, now everything works. Thanks for the help, Dave
buzzbomb is offline
Electrical gremlins pcv57 ZJ Grand Cherokee Forum 2 01-28-2010 12:29 PM
electrical gremlins JackStraw ZJ Grand Cherokee Forum 2 09-30-2009 09:43 PM
Electrical gremlins TPS/IAC Chloetar ZJ Grand Cherokee Forum 3 05-24-2007 09:40 PM
electrical gremlins crexor ZJ Grand Cherokee Forum 0 01-21-2007 03:15 PM
Electrical gremlins Beachy ZJ Grand Cherokee Forum 6 09-10-2006 11:06 PM
