Electric fan vibration , 5.9 - JeepForum.com
post #1 of 1 Old 11-04-2009, 05:15 PM Thread Starter
newfieZJ
I have a pretty decent vibration when the E-fan switches to high . No noticable change in the voltage .
I did changed the rad and noticed there are 2 small tabs/clips that hold the fan underneath . They seem to be loose and don't snap tight allowing the fan to move back and forth about 1/2 inch on the bottom only . Is this normal , or should I get new clips ? Seems to work as it should right now , but not something to let go to chance either . I could tie a tie-strap on the shroud but want to fix it properly .
If you had this issue , what was your fix ?
Thx
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
4.0 I6 with Electric and mechanical fan. can use only electric? djoy ZJ Grand Cherokee Forum 2 07-18-2009 07:25 PM
Electric Fan - Please Help!!!! jeepsterbabe ZJ Grand Cherokee Forum 2 06-14-2007 01:27 PM
New Electric Fan! Jmila1901 ZJ Grand Cherokee Forum 1 03-07-2007 05:37 PM
5.9 electric fan nashmd454 ZJ Grand Cherokee Forum 3 04-07-2005 08:09 AM
Electric fan on a 93? Crazed ZJ Grand Cherokee Forum 3 04-18-2004 09:47 PM
