EGR Valve Help Please - JeepForum.com
post #1 of 8 Old 07-20-2011, 11:55 AM Thread Starter
TewSmooth18
Does a 5.2 V8 have a EGR Valve? If so, can somebody tell me where it is located at, or take a picture so I know what i'm looking for. Also, is the EGR Valve something that can be cleaned? As in does it get carbon build up on it kind of like the IAC?
97 Grand Cherokee 5.2 V8 - 242 swap - everything else stock atm
TewSmooth18 is offline
post #2 of 8 Old 07-20-2011, 02:48 PM
vonericsen
If you have a 93 to 95 you should have an egr. If you do it is located on the back of the intake manifold and I think it is the passenger side. I don't know if that is something that can be cleaned.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #3 of 8 Old 07-20-2011, 04:42 PM Thread Starter
TewSmooth18
i've got a 97 GC. from some more research I don't beleive i have an EGR valve, but correct me if im wrong
post #4 of 8 Old 07-20-2011, 04:46 PM
Dodgeram1989
1976 FSJ Cherokee
My 97 with a 5.2 doesn't have an egr
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #5 of 8 Old 07-20-2011, 06:18 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
obdii 5.2 motors do not have the egr, there's no need for it with the better computer control after 1996.
ratmonkey is offline
post #6 of 8 Old 07-20-2011, 06:19 PM
rm2001wj
rm2001wj's Avatar
EGR system only on 93-95 V8.
rm2001wj is offline
post #7 of 8 Old 02-07-2015, 08:59 PM
Joe16
I have a 97 Jeep Grand Cherokee limited 5.2 liter. Replaced the crankshaft position sensor, when I step down on the throttle, it does not rev up right away, instead it starts to die. What is happening? Help
Joe16 is offline
post #8 of 8 Old 02-07-2015, 11:35 PM
Uniblurb
Uniblurb's Avatar
You should probably start your own thread instead of reopening an old thread about EGR valves.
Regardless, I see this is your 1st post and welcome to the forum
What brand of crank sensor did you buy? If not Mopar that's probably your problem. There's a couple crank sensor test in my signature if you have a multimeter. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
PCV Valve on Valve Cover? Krayzie949 ZJ Grand Cherokee Forum 22 08-14-2011 05:08 PM
PCV Valve..Not...There? 07 WK help! Natemare13 WK Grand Cherokee & XK Commander Forum 5 11-01-2009 06:13 AM
PCV Valve, tope of valve cover... random155 ZJ Grand Cherokee Forum 9 01-07-2009 10:15 PM
Bad EGR Valve?? GrandRubicon155 ZJ Grand Cherokee Forum 6 04-17-2005 11:50 PM
EGR valve and IAC valve dmask0 ZJ Grand Cherokee Forum 1 11-02-2003 01:39 PM
