Effects of changing fuel pump to '95 model on 93 zj - JeepForum.com
post #1 of 4 Old 12-11-2011, 06:49 PM Thread Starter
wvpv
I have a 93 zj with a 4.0 that has had the factory fuel pump replaced with a pump from a 95 or 96 zj. The return fuel line has simply been plugged and pressure at the rail reads around 52psi all the time. (I believe the stock system functioned a 31psi at idle, 40psi under load). How would you expect this to affect performance? I get highway mileage of around 17mpg and less than half that in town. I believe that the pump is failing and am wondering if I should restore the stock system when I replace it.
Thanks
wvpv is offline
post #2 of 4 Old 12-12-2011, 12:43 AM
zander21510
that definitely doesn't sound right at all. Somebody probably half-assed the job to just get it to run. You probably run pretty rich, which explains your dismal mileage. And no wonder the pump is failing running at that pressure. Definitely replace with a stock system.
zander21510 is offline
post #3 of 4 Old 12-12-2011, 01:20 AM
TheHalfWit
X2, my 95 gets better mileage and its currently lacking a functional O2 sensor.
Sent from my iPod touch using JeepForum
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #4 of 4 Old 12-12-2011, 12:16 PM Thread Starter
wvpv
Thanks guys,
Do you know which pump I should go for? Is the Bosch worth the extra $60-$80 dollars over a Denso, Carter, or Delphi? Thanks
wvpv is offline
4.0l , fuel pump
New aftermarket high quality fuel pump? second pump in 3 years?!!!!? SPL Tech ZJ Grand Cherokee Forum 8 11-02-2010 05:12 PM
Changing the OIL PUMP.... nat441 ZJ Grand Cherokee Forum 2 03-24-2008 11:21 PM
Changing fuel pump tomorrow... spros95jeep ZJ Grand Cherokee Forum 12 09-21-2006 06:51 PM
Changing water pump 2000 GC ron4488 ZJ Grand Cherokee Forum 1 10-09-2005 06:42 PM
Changing Out A Water Pump CATMAN2 ZJ Grand Cherokee Forum 1 10-20-2003 04:57 PM
