EFFECTIVE coolant flush alternatives... - Page 2 - JeepForum.com
post #16 of 25 Old 09-16-2013, 09:41 AM Thread Starter
congerz83
BTW... This is about where my ZJ normally sits temperature-wise... A little hot, no?
congerz83 is offline
post #17 of 25 Old 09-16-2013, 10:09 AM
dusterdude
Thats not too bad,mine runs about 220
dusterdude is offline
post #18 of 25 Old 09-16-2013, 06:47 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
http://www.aa1car.com/library/coolin..._corrosion.htm
Makes for a good read
Originally Posted by HighLonesome
coralman is offline
post #19 of 25 Old 09-16-2013, 08:29 PM
AnotherRedZj
Originally Posted by coralman View Post
Good post.
AnotherRedZj is offline
post #20 of 25 Old 09-16-2013, 08:59 PM
zjosh93
^^^ This.
On the cars that I maintain I always make sure that the battery cables are in very good condition and usually add a couple extra ground wires to link things that normally ground just through the mounting bolts. I have seen dramatic reductions in corrosion on both battery terminals and cooling system parts.
zjosh93 is offline
post #21 of 25 Old 09-17-2013, 03:21 AM
coralman
coralman's Avatar
Thanks for the thumbs up!
coralman is offline
post #22 of 25 Old 09-17-2013, 06:04 AM
AnotherRedZj
post #23 of 25 Old 09-17-2013, 09:49 AM
V65Ozzie
Originally Posted by Uniblurb View Post
Hopefully you have your heater set to high when flushing the system so it goes through the heater core. Also helps to back flush the core and disconnect your hoses at the front/right of the valve cover rather than possibly damaging the soft copper tubes coming out of the firewall. When I replaced my AC evaporator I also replaced the heater core and while I was trying to be careful I could not get the hoses off of the core w/o bending or half-crimping these soft copper tubes. Didn't matter since was replacing the core anyhow.
No need to worry about the heater setting, the heater core is always at full flow, what controls the amount of heat is the blend doors in the plenum. Agree with back flushing the core, also, check the heater hoses for crunchiness, just squeeze them, if they crunch, slap new ones on, corrosion tends to build up in them, in my 97 they got so bad that the heat wouldn't work, I replaced them, flushed the core, and all was good with the world, and my coolant stayed cleaner also,
Retreat? Hell, we just got here......
V65Ozzie is offline
post #24 of 25 Old 09-18-2013, 04:47 PM Thread Starter
congerz83
Yeah... I'm gonna plan to replace the whole system. Radiator, hoses, water pump.
I'm planning on treating myself to a block heater. I figured it would be easier to punch out a freezeout plug if the block was empty...
post #25 of 25 Old 09-25-2016, 03:52 AM
AZSobo
Location: Somewhere in the desert west of New Mexico and east of California.
I know I'm 3 years late to this party but in regards to using the Prestone back flush kit, I did it a few years ago and stuffed an old garden hose into the spout to control the output of nasty. I can't remember if I put a clamp on it or not but it didn't leak and it wasn't showering my front end with coolant.
2001 Jeep Wrangler Sport, 4.0L, 30x9.5 15 Tires on Alum. Rims, Tomken Bumpers front and rear - Everything else Stock
AZSobo is offline
