eccentric cam Q - JeepForum.com
post #1 of 5 Old 08-18-2011, 05:35 PM Thread Starter
Darman
eccentric cam Q
doing the rough country 4 in lift. it says mark the eccentric cam on the front lower control arms before removing.
is this picture what they mean? just make a line so i can put that "washer" back the same way as it was before? and theres one on each side of the front lower control arms correct? only on the axle side tho?
Darman is offline
post #2 of 5 Old 08-18-2011, 09:15 PM
KJK
You are correct. You see that line on the "washer"? Just make a mark on the bracket next to it so you can clock it correctly upon reassembly.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #3 of 5 Old 08-18-2011, 11:10 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Holy christ on a pogo stick.
Resize your images before posting.
Or use photobucket and post the thumbnails.
ratmonkey is offline
post #4 of 5 Old 08-24-2011, 12:51 PM Thread Starter
Darman
and what exactly does the eccentric cam bolt do?
Darman is offline
post #5 of 5 Old 08-24-2011, 01:25 PM
speedbucket
more like "HOLY DARMAN ON A POGO STICK, JUMPING FROM THREAD TO THREAD!"
it just gives setting points from one side control arm to the other for keeping the axle sqaure and caster the same from one side to the other
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
