"Easy" mods? 94, 4.0 - JeepForum.com
post #1 of 14 Old 08-14-2011, 12:15 AM Thread Starter
DustinV89
1994 ZJ
Well I'm working on switching from a 94 explorer 4x4 to a 94 GC ZJ 4.0 2x4, the explorer is giving me too many problems with a bad shake on braking.
Anyway, I've been looking for things I can do to customize a stock ZJ that are "simple." This isn't for offroading or anything, just a daily driver on the highway/normal streets to school/work etc.
So far I have on my hypothetical list... Replace stereo and speakers, either cold air intake or high perf air filter (opinions?) as well as replacing all the floor mats etc. I also was looking into replacing some of the interior panels, a lot of them are pretty scratched up and I was either looking for a good place to buy these or maybe just a way to clean em up. I need to clean up the yellowing headlights or replace them as well.
Does anyone have any simple mods to suggest? I'm kind of in the "easy-medium" range at this point.
DustinV89 is offline
post #2 of 14 Old 08-14-2011, 01:20 AM
ctak24
tune up and brakes is always a good start as well as replacing all fluids
ctak24 is offline
post #3 of 14 Old 08-14-2011, 01:31 AM
ravinsaend
for a daily driver I would definitely look into upgrading the injectors. You'll get better throttle response, meaning less pushing down the pedal to get to speed, and no mashing the pedal on the bigger hills, either. This means while technically it won't up your mpgs, it will still help in that dept. It just increases overall efficiency of the fuel system, and there are tons of threads on here about it, just do a search.
Also, a note about the intake: The 4.0s get all the air they can handle without a better flowing exhaust, so unless you want to upgrade that at some point, your intake will be pointless. This isn't from personal experience but it seems to be majority consensus.
ravinsaend is offline
post #4 of 14 Old 08-14-2011, 09:53 AM
sabzz
What injectors do you use? I know the ford 5.0 ones work, but from what years and from the trucks or the mustang 5.0? I'm looking into getting some for my 4.0 since everybody says they tend to help out a little bit with efficiency.
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
post #5 of 14 Old 08-14-2011, 10:23 AM
stmprnch
Injector Thread
Here's a thread with 11 pages of posts. Probably more than you really want to know but there are some diamonds in this coal field.
http://www.jeepforum.com/forum/f13/d...4-0-a-1145336/
Best
'93 GC (ZJ) Selectrac
4.0L I6 BORED & BALANCED @ 225k; AW4 Auto; NP242 TC
PROTHANE IN CA's & TA's; DAYSTAR URETHANE COIL SPACERS & BUMP STOPS; HOTCHKIS SWAYBARS
stmprnch is offline
post #6 of 14 Old 08-14-2011, 10:27 AM
sabzz
Alright thanks!
sabzz is offline
post #7 of 14 Old 08-14-2011, 11:43 AM Thread Starter
DustinV89
1994 ZJ
Exhaust is a possibility, but not till a while later. I'll check out the injector mod, fluid, brakes, etc. Anyone know anything about oil filters? I was looking at random parts and replacements and came across some "high performance" ones... are these just a claim or worth something?
post #8 of 14 Old 08-14-2011, 01:53 PM
TheHalfWit
Generally an oil filter is an oil filter, as long as its not produced by honeywell they all accomplish similar things. K&N has a bit of a following, but really all oil filters do the same thing.
You will not get any performance boost from using a performance oil filter, just so that points clear.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #9 of 14 Old 08-14-2011, 02:08 PM
RedneckZJ
you can get an intake off a 4.0 wj. direct bolt on and flows better so ive heard
'96 ZJ Orvis 5.2L (Mossy Oak Edit.)- UC+2" BB, Thrush Turbo, 2 12s, Lots Of Stickers
You drive a tj, we drive a zj. We have more power while you get more shower. We get the v8 while you get there too late. You have 2 doors well, we have 2 more. Ours costs a grand while yours has a price we cant stand.
RedneckZJ is offline
post #10 of 14 Old 08-14-2011, 02:25 PM
zander21510
I've done a lot of the easy mods...I think I posted most on my blog. Pm me if u have any questions on istock airbox mods and the injector swap...together they do make a noticeable difference
Sent from my Nexus One using JeepForum
zander21510 is offline
post #11 of 14 Old 08-14-2011, 10:42 PM
TheHalfWit
Not quite, since the op has a 94 he would have to switch his pulley setup. It would be truly bolt on for you since the 96 and the wj has the same pulley arrangement for 4.0.
Calm. C.
post #12 of 14 Old 08-14-2011, 11:51 PM
zander21510
Maybe next summer I will make that my project, I have been wanting to do it but i ran out of time this summer :P i can't do anything in a college parking lot after all...
post #13 of 14 Old 08-15-2011, 12:23 AM Thread Starter
DustinV89
1994 ZJ
I was looking at the air box off my wrecked 96 zj and I'm pretty sure its the same as on the 94, what kind (size, location) of holesshould I drill for better air flow? I know they have to be before the filter obviously, I just want to do it right before I drill into my only spare air box.
Also, are there any parts I can salvage off the 96 that might be good to swap or keep as spare parts? Both are 4.0s.
Thanks again
post #14 of 14 Old 08-15-2011, 06:52 AM
melk
I did the injector swap (used Chrysler #703 not the Ford) and a little while later did the dubjay intake manifold swap as well.
In my experience the injectors did help but the manifold made the most difference. I'm getting a consistent 18 mpg now as long as I don't go WOT up hills too much used to be 15-16 avg.
Next up is exhaust manifold/header and 2.5" pipe.
OP - It might not be sexy but basic maintenance really is your best bet for keeping your Jeep running problem free. Ignition tune up, fuel filter, all fluids (motor oil, tranny, diff)
melk is offline
modification , zj
Problem with "easy entry/exit seat" makinitrain08 WK Grand Cherokee & XK Commander Forum 5 08-12-2011 11:33 AM
the never ending "easy" job (long but good) Irish_Assassin ZJ Grand Cherokee Forum 11 08-18-2010 02:23 AM
A few "Light" mods JohnDeerCJ WK Grand Cherokee & XK Commander Forum 9 02-23-2010 06:11 PM
easy 3" lift 94GCL420 ZJ Grand Cherokee Forum 8 02-22-2010 09:43 AM
Exhaust flanges for easy removal--3" ZJcrawler45 ZJ Grand Cherokee Forum 5 08-24-2009 01:44 AM
