Easy fast fix for idle drop off/stall - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Easy fast fix for idle drop off/stall
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGrizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! Brough
Unread 08-18-2014, 09:33 PM   #1
Saskattak
I mentioned before I found a 97 Ltd, 5.2 that wasn't running (dies when left to idle), body/interior perfect shape...got it for $500. The fella said he switched out some sensors even, nothing helped. Thanks to this forum I went straight to the idle sensor on the throttle body...BINGO! Literally 1/8" of gunk on the end of the senor. cleaned that and the throttle body and the engine starts right up and IDLES without issue.
Moral of the story...check the forums, not your mechanic.
Saskattak is offline   Reply With Quote Quick reply to this message
Unread 08-19-2014, 10:49 AM   #2
NTH
Great tip! Thanks
NTH is offline   Reply With Quote Quick reply to this message
