Easy brake swap. - JeepForum.com
post #1 of 9 Old 08-16-2009, 04:41 PM Thread Starter
MarkoPo
MarkoPo's Avatar
2005 WK
Easy brake swap.
I just changed the rear pads and rotors on my 96 GC I could not believe how easy it was to do. I had both sides done in less than 20 minutes. They were horrible. The inside pad on both sides had grooves cut into them, and the rotors were very rusty. I just used a little PB blaster and a few good hits from my BFH and they came right off. The parking brake pads inside the rotor were junk, so I didn't bother replacing any of that stuff. After I got all done I pulled a spark plug and it was pretty worn so I threw 6 new Champion plugs in it and broke a wire pulling one off. So then back to the parts store to buy a set of wires. It runs great now. I threw 2 cans of R-134A in and the air conditioner blows cold air. I am very happy with this purchase. I paid $2500 out the door forthe Jeep $76.00 for rear pads and rotors, $20.00 for 2 cans of freon, $20.00 for new wires, and $15.00 for 6 new plugs. It runs great, and the interior looks like new still. Hard to believe for a vehicle that is 13 years old and has 122,000 miles on it. I'll post some pictures of it later this week.
05 Grand Cherokee Limited 5.7 Hemi
06 pontiac Torrent AWD
96 Grand Cherokee Laredo 4.0 newest edition to the family.
Hemi Club member #2
Bonafide Gun Guru
MarkoPo is offline
post #2 of 9 Old 08-16-2009, 04:55 PM
SouthSeaPirate
Wish I could say the same for my drums
Good deal! Did you notice a difference in running quality after plug and wire change?
SouthSeaPirate is offline
post #3 of 9 Old 08-16-2009, 04:57 PM
moparrr07
welcome to working on chryslers, gm isnt quite the same
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #4 of 9 Old 08-16-2009, 05:05 PM Thread Starter
MarkoPo
MarkoPo's Avatar
2005 WK
It does run better. When I took it to town this morning I noticed it hesitated a little starting up. It seem a little more spunky now. The plugs were well worn down, but none were fouled so that was a great sign.
You must of read my epic of changing the wheel bearing on my wife's car.
Hemi Club member #2
Bonafide Gun Guru
MarkoPo is offline
post #5 of 9 Old 08-16-2009, 05:44 PM
TMCXJ
I love Jeeps, and working on them... non-jeep friends say that it's a good thing I like to work on them 'cuz I have to do it so often. Not necessarily true.............
I know what you mean about the brakes - my wife's Ford Taurus? A supreme pain in the buttocks for the rears when the caliper doesn't want to cooperate with the idiotic "crank the piston back into the caliper" routine, and there's nothing you can do about it except replace the caliper, but then if the piston won't turn back into the caliper because of rust or age, odds are you can't remove the brake line from the caliper, either!!!!.... and the thermostat on the 3.0 Duratec V-6? AAARRRGGHHHHHHH!!!!!!!! It's on the BOTTOM of the friggin' engine! Gotta remove the exhaust bank, remove the tansaxle mount, raise the engine/transaxle, REMOVE THE CROSSMEMBER!!!, and THEN you can remove the thermostat housing!!!!!!!! Some insane engineer on the worst day of a bad week and suffering from the downside of a manic-depressive swing drew the short straw for designing that thing and he decided to take it out on mankind in the worst possible way.... nothing goes back together quite the way it's supposed to, either.... needless to say, I've only changed it once (only HAD to, that is); now, the spring on the passenger front strut broke, so the 97 ZJ is going on the road a little bit ahead of schedule.
Did I mention that i love Jeeps, and working on Jeeps???
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
post #6 of 9 Old 08-16-2009, 06:14 PM
moparrr07
no i had no idea, ive just done alot of work on chryslers and alot on gm, gm engineering is really a joke, everything they do is really hard to get to or you have to take 4729947 things off to get to it
post #7 of 9 Old 08-16-2009, 06:17 PM
Jones
Consider the following...
Jones's Avatar
Sounds like a good find. Any other plans for the jeep or is it going to stay stock?
Jones is offline
post #8 of 9 Old 08-16-2009, 06:34 PM Thread Starter
MarkoPo
MarkoPo's Avatar
2005 WK
It is going to be my daily driver, so it will probably stay stock for now. I found some receipts in the glove box and called the previous owner. He said he had no problems with the vehicle at all. It had new tires and shocks put on it 22,000 miles ago. The ABS light is on and the cruise doesn't work so I'll work on those issues in the next few weeks. When I drove it home from the dealer I was playing with the stereo and hit the CD button and it said reading. I was like WTF?! Well someone left an insync CD in it. I told my wife when I got home either a girl or some flammer owned it before. Turns out I was right. It was the guy's 19 year old daughter's car. she drove to to college and back. They only put 24,000 miles on it since 2005.
Hemi Club member #2
Bonafide Gun Guru
MarkoPo is offline
post #9 of 9 Old 08-16-2009, 06:43 PM
SouthSeaPirate
My OD and Cruise didnt work when I got mine. Had a few codes including the TPS. Replaced that and all was well, even ran a bit better.
Good to know the plugs make it run better; I think Ill be doing that when I replace my WP.
Easy brake job turned into nightmare Indslpwr04 ZJ Grand Cherokee Forum 18 09-02-2009 07:07 AM
2004 GC 4.7 Easy Flowmaster Swap? 2THEXTRM ZJ Grand Cherokee Forum 2 12-31-2008 03:33 PM
E brake cable broke easy fix?? CrazyDrivinJoe ZJ Grand Cherokee Forum 5 02-29-2008 10:22 AM
4wd swap made easy. anticrombie ZJ Grand Cherokee Forum 10 06-25-2006 10:53 AM
Easy Front Brake Question midwest97gc ZJ Grand Cherokee Forum 4 02-02-2005 10:31 AM
