Easiest Way to disable ZJ? - JeepForum.com
post #1 of 65 Old 01-14-2015, 07:16 PM Thread Starter
esu
Guys, let me explain my predicament. My family is estranged from our 27 yr old son. I believe he has a key to my 95 ZJ 4.0. I believe he has used it or will use it when we are at work. Is there any way to simply disable the truck that I can undo and redo easy enough that maybe my wife can do also? Any help appreciated as always, thank you, Cory.
esu is offline
post #2 of 65 Old 01-14-2015, 07:22 PM
paxbnm
paxbnm is offline
post #3 of 65 Old 01-14-2015, 07:22 PM
vlackattack
I believe there's a relay in the fuse box under the hood for the starter, taking that out will keep it from starting. Probably the easiest method.
vlackattack is offline
post #4 of 65 Old 01-14-2015, 07:46 PM
firsttimeZJ13
Pull the asd relay and leave it in a location only you and your wife know about. Preferred not somewhere in the Jeep.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline
post #5 of 65 Old 01-14-2015, 08:02 PM
kensnelling
If it was me, I'd pull all 4 lock cylinders and take them to a locksmith to be rekeyed. As it is right now, even if you disable it so it won't start or run he can still get inside it (and open the hood too) and do some sabotage himself, if he's so inclined.
Ken
kensnelling is offline
post #6 of 65 Old 01-14-2015, 08:11 PM
xcaliber81
Ken
Where's the 4th lock cylinder? The thing with pulling a relay is its easy enough to replace. Think about installing a kill switch I once thought to put a kill switch in the window lock but then you would loose the window locks.
xcaliber81 is offline
post #7 of 65 Old 01-14-2015, 08:19 PM
riot1987
I wanna do something similar to mine as well
Build thread^^
riot1987 is offline
post #8 of 65 Old 01-14-2015, 08:20 PM
dflewelling
Disconnect the driveshafts lol
dflewelling is offline
post #9 of 65 Old 01-14-2015, 08:22 PM
Cbob4
It might be best to pull the fuel pump relay. That way, she'll turn over but not start, he'll just think it's a Jeep thing. Pull the starter relay, where the ZJ does nothing when he turns the key, and he'll probably figure out you've done something to keep him from using it...and he'll get pissed. Getting pissed, he very well may take it out on the ZJ...
Cbob4 is offline
post #10 of 65 Old 01-14-2015, 08:30 PM
dflewelling
Remove the serpentine belt...or the engine. Nah but seriously the fuel pump relay would do it...my 95 5.2 will not run or start without the MAP, that would be quick and effective, much more effort on his part to go that route rather than replace a relay...
post #11 of 65 Old 01-14-2015, 08:39 PM
kensnelling
Both front doors, liftgate, and ignition. You could just do the doors and the liftgate, but then you need to carry 2 keys.
Ken
post #12 of 65 Old 01-14-2015, 08:58 PM
CatSplat
1994 ZJ
If you're going to pull relays, pull at least 2 of the fuel/ASD/starter/wiper relays so he can't just swap the wiper relay in for the one you've pulled, since they're all the same relay.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #13 of 65 Old 01-14-2015, 09:35 PM
Cbob4
One thing we haven't considered, since the OP hasn't posted back...does this dude have the smarts to figure out how to get around the disabling? I am curious to know whether this dude knows his way around a ZJ...
Cbob4 is offline
post #14 of 65 Old 01-14-2015, 10:52 PM
Uniblurb
Uniblurb's Avatar
^ thought the same thing and are you going to pull all the relays since the kid may just take the horn relay and stick it in where the ASD or fuel pump relay was removed?
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
post #15 of 65 Old 01-14-2015, 11:06 PM
SchizophrenicMC
2016 JK Wrangler
How often is the ZJ used? I assume fairly frequently because your wife needs to be able to disable and reenable the Jeep as well?
If you use it frequently, your best bet is probably going to be removing the Automatic Shut Down (ASD) relay and fuel pump relay. These are both necessary, and there aren't enough of the type of relay they use in other spots, to swap in relays for both, and still be able to start the Jeep.
If you use it fairly infrequently, you could disconnect the crankshaft position sensor. This is a real pain to get at, and without it, the Jeep will crank and crank and crank, but never start, no matter what relays are left in the box. It's not easily visible from under the hood, or under the vehicle, and if you don't know what to look for, you probably won't see it behind everything ahead of it. Of course, if you need to reconnect it quickly, you'll need a lot of practice reaching down into the right spot.
Signature rules are dumb
SchizophrenicMC is offline
