E Fan Sensors (5.9->5.2) - JeepForum.com
post #1 of 6 Old 01-25-2014, 06:31 AM Thread Starter
Jeep98_zj
Folks:
OK...amazingly enough found a 5.9 in a JY...
I salvaged the 2 temp sensors from the bottom and top hoses.
Questions:
-What temps do each sensor activate?
-I only planned to install one to activate the low side of my fan (all I need even in SC!)...Which hose should I use?
Thanks!!
Jeep98_zj is offline
post #2 of 6 Old 01-25-2014, 06:43 AM
newfieZJ
upper hose activates the low speed relay which give the power to the fan . Relays are located just behind the battery on the fender
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 6 Old 01-25-2014, 03:13 PM
jeepjeepster
They be the exact same. Upper and lower sensors that is.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #4 of 6 Old 01-26-2014, 01:38 AM
newfieZJ
True , but , you want it in the upper hose especially as a single . The lower will activate the high speed only if the coolant didn't cool off in the rad enough .
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #5 of 6 Old 01-26-2014, 06:47 AM Thread Starter
Jeep98_zj
THANKS! That makes perfect spence now!!
post #6 of 6 Old 01-26-2014, 08:11 AM
50notch
The low speed kicks on at 213* and the high speed kicks on at 220*
1998 Grand Cherokee 5.9 - DT headers, Kolak 3" exhaust, 2" BB, K&N CAI
50notch is offline
