E-fan install help ASAP!! - JeepForum.com
post #1 of 7 Old 10-02-2009, 07:36 PM Thread Starter
DothanJeep
In the middle of installing an e-fan with a Flex a lite VSC, looking for the easiest " switched power " location, under the hood.
Thanks guys!!!!
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline
post #2 of 7 Old 10-03-2009, 12:33 AM Thread Starter
DothanJeep
Anyone?.........
post #3 of 7 Old 10-03-2009, 05:02 AM
Jones
Consider the following...
Jones's Avatar
Check EMTimZJ's build thread on MallCrawlin. I think he did a write up on this. It may even be posted on here somewhere but I'm not sure.
Jones is offline
post #4 of 7 Old 10-03-2009, 06:57 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
i did a little relay rewiring in the pdc to get an automatic switched power source.
ratmonkey is offline
post #5 of 7 Old 10-03-2009, 10:04 AM Thread Starter
DothanJeep
yeah he did, that was some of the scariest, sloppiest wiring I have ever seen.
I found a switched power ( coolant level sensor) but when you plug it back in..the fan stops working.
Anyone know of an other places?
post #6 of 7 Old 10-05-2009, 07:37 AM Thread Starter
DothanJeep
Anyone? ...........
post #7 of 7 Old 10-05-2009, 07:47 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I soldered a wire to an ASD relay prong in the PDC. I'm an expert solderer... used to do it for a living, so that was easiest for me. I solder to the top of the prong and the relay plugs back in as normal. Another way would be to locate the coil side wire for the ASD relay and tap it at the PDC harness.
HighLonesome is online now
someone with a 4.7 wj please help me asap. zippome ZJ Grand Cherokee Forum 11 12-07-2009 06:24 PM
NEED HELP ASAP..in the middle of SYE install lakailimited06 ZJ Grand Cherokee Forum 0 08-02-2009 03:34 PM
Front lift install problem.. need help asap UTChavok ZJ Grand Cherokee Forum 3 06-26-2008 08:11 PM
S.o.s.!! Need Help Asap!! kmd1776 ZJ Grand Cherokee Forum 12 03-10-2008 03:32 PM
skid plate install, need help asap enzio ZJ Grand Cherokee Forum 4 02-18-2008 06:23 PM
