#1 | |
Belief In All Things Jeep
E-fan controller schematic
Whelp, here is the first edition. Has all the bells and whistles...status indicators (optional, can be bulbs or LEDs), fan disable, fan Hi/Lo override, auto mode (switches fan Off/Lo/Hi as necessary), AC compressor turn on to Hi, protection diodes, high current (will easily handle the Mopar and Taurus fans), you name it. Improvements are welcome. I will revise the schematic when needed.
SCROLL DOWN FOR UPDATE!
#2 |
Thanks so Much, This is Great
Hey there,
It's Paul from the other website. Thanks much this great stuff. This is the kind of stuff I join car clubs for. Might there be a tap in place already in our main electrical box under the hood for the main tap? I do think I've got the 120 amp alternater. Was there a tougher one for ZJ's and can any ZJ's harness handle the extra power? With the winter coming I don't think I'll get a chance to tackle this one now. Perhaps I'll collect the parts and get on it next spring in time for the next AC season. So either the Tauras fan or the 5.9 ZJ fan will work with this set-up right? What are the issues with hooking up the Ford fan to the back of a ZJ radiator? It might pay to be picky and make sure you get the Jeep one I might imagine. Wish I could find a "parts" victim. Yeah, just part out a good 5.9, right? Anyway, thanks again and have a great night..... Paul |
#3 |
man dude, u have so much **** on there lol.. im going simple with mine. high and low run to a switch in the cab.. lol
ur goin all out..
- John - 22 and learning <-- ORIGINAL -Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff RIP Troy Edwards
#4 | |
You're welcome and thanks! Call Lawrence at www.mopartsracing.com and see if he can get you a Mopar efan/shroud. Last time I looked (4 years ago ), they were only $161 + ship.I would grab ignition 12vdc from the switch of the ASD relay. That relay much be engaged for the motor to run, so it makes sense. Just lookup the wire and splice it before it goes into the distribution box. The 120 amp alt will work, but minimal. You can get a 136 amp at Autozone, or try to find a 150 amp from a niner. No worries about the stock harness, since you are making your own and only using ignition to power a relay. Your efan gets wired directly to the battery. The Taurus fan shroud is an odd shaped thing that doesn't give full coverage and doesn't fit flush to the rad in places. If you are in a hot area, you will press it to the limits. I mounted mine to the old shroud for ease of mounting and to get a little more coverage. Here's the writeup http://www.jeepforum.com/forum/f13/ford-3-8-efan-project-begins-355400/ Some stuff for sale, sounds like the fan needs a motor http://www.jeepsunlimited.com/forums/showthread.php?t=844193 Cheers |
#5 | |
I did the diagram with all the bells and whistles, but it can easily be scaled back and simplified. I started with a Cadillac, but it can be modded into a Chevy. |
#6 | |
well im planning on tapping the wire to one of the ignition wires.. so i dont think ill need to worry about that
#8 |
Mr. Hyde!
Why don't you want the compressor coming on when the fan is on? Just to help it cool before the compressor kicks back on? Seems like in a hot climate you could get stuck with no AC like that.
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#9 | |
#10 |
Mr. Hyde!
Roger that
#11 |
I have the 5.9 fan, sensors, and relays so I want to do it the right way and not use a fan controller. Im thinking I can just run the low and high wires to the battery with the high and low 5.9 relays in between and then use the rad. hose sensors to trigger each relay. Where do I put the third relay so when high comes on it shuts off low speed? And do I need to hook up the AC? I figure if it gets hot running the AC the sensors will trigger the fan anyway
97 JGC Limited 5.2L, Black/Black, NP242 swap, D44a with LSD, 3.73 Gears, 2" IRO lift, Zone Nitro shocks, BFG KO's, Doug Thorley Headers, Magnaflow High Flow Cat, Flowmaster Super 44, Custom Tail Pipe, 5.9 E-Fan Conversion, SCT Tune by Sean, K&N FIPK, Amsoil filter/Pre-filter, MSD 6AL Ignition Box, Blaster SS Coil, Alpine Type-S speakers, Alpine 500W Amp, 10" Kicker CVR, Receiver Shackle, Custom Dash Bezel |
#12 |
Just a thought on the high/low/auto manual override switch. I would probably put that downstream of the relays as a safeguard for relay failure, if that would make sense.
Then again the would remove the auto control function. Gonna have to think more on that and how to set it up for a backup/override.(Edit) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
