DW/trac bar bracket question - JeepForum.com
post #1 of 17 Old 09-21-2009, 12:18 PM Thread Starter
Jeepfordan
Sorry if this has already been asked, but I couldn't find anything in a quick search. I just installed the IRO 3.5 lift kit, and now I have DW so bad that the jeep is scary to drive. I got the adjustable front trac bar, but the kit also came with a drop bracket. I'm a little confused. Do I need to put the drop bracket on with the adj. trac bar? I've changed the CA bushings, adjusted the toe in and had it aligned.
Jeepfordan is offline
post #2 of 17 Old 09-21-2009, 12:23 PM
the88thpianoman
2003 WJ
Only use the track bar, do not install the drop bracket.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 17 Old 09-21-2009, 12:29 PM Thread Starter
Jeepfordan
thanks, thats what I thought. Im going to get under it after work and check the SS and the torque on the trac bar
post #4 of 17 Old 09-21-2009, 12:40 PM
rugermack
Check, ca bushings, steering, any loose parts.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #5 of 17 Old 09-21-2009, 01:25 PM
fsSnowboard
wrong forum...oops
fsSnowboard is offline
post #6 of 17 Old 09-21-2009, 02:06 PM Thread Starter
Jeepfordan
Thanks, ill be checking all of that after work
1998 XJ- 4.0/AX-15/231- 3.5" RE. 4.10 gears - 4.6 build in progress.
post #7 of 17 Old 09-21-2009, 02:10 PM
vosevichs
Which track bar did you get? The one that comes in the kit needs the bracket. They sell another track bar that has the tie rod end in it.
Scott Vosevich
vosevichs is offline
post #8 of 17 Old 09-21-2009, 02:12 PM Thread Starter
Jeepfordan
The adjustable trac bar that comes with the kit needs the drop bracket? I notiiced that it did not have anywhere near the same bends as the stock bar, is that why? My axle is fairly well centered right now without it
post #9 of 17 Old 09-21-2009, 02:20 PM
vosevichs
The 3.5 in kit
IRON ROCK OFF ROAD: ZJ 3.5" Lift Kit
XJ/ZJ Double shear adj. track bar conversion
IRON ROCK OFF ROAD: XJ/ZJ Adjustable Double Shear Track Bar Conversion Kit
Their XJ/ZJ/TJ Adj. track bar
IRON ROCK OFF ROAD: XJ/ZJ/TJ Adjustable Track Bar
Which bar do you have?
Alot of people are replacing the bushing with a harder durometer bushing
Scott Vosevich
post #10 of 17 Old 09-21-2009, 03:04 PM Thread Starter
Jeepfordan
I have the 3.5in kit with the XJ/ZJ Double shear adj. track bar conversion. For some dumb reason I was under the impression that I wouldnt need the bracket
post #11 of 17 Old 09-21-2009, 03:13 PM
vosevichs
You haven't even put the track bar in yet and you have DW. So you checked everything over and it's all tight. Put the new track bar in. Hopefully it will solve your DW
Scott Vosevich
post #12 of 17 Old 09-21-2009, 10:59 PM
tazimafied
If you have the adjustable track bar, the track bar drop bracket isn't necessarily needed. If you end up getting a drop pitman arm I would recomend using the drop bracket to keep the track bar and steering link as parrallel as possible. If the two are not parrallel bump steer will increase and may induse death wobble. For those using the drop bracket, don't trust the bolt alone. It will still move around and cause death wobble. Weld it in place. You can do it your self or take it to a shop and have it done. Either way you will alleviate a lot of headaches and scary moments.
Because I felt like it!
tazimafied is offline
post #13 of 17 Old 09-21-2009, 11:06 PM
CaptainZJ
1994 ZJ
I had that problem after I installed my lift, it was just out of alignment.
CaptainZJ is offline
post #14 of 17 Old 09-22-2009, 03:33 AM
sandman
if you have the double shear track bar you cant even install it without the drop bracket. this thread is confusing.
1993 Jeep ZJ. 4.0
sandman is offline
post #15 of 17 Old 09-22-2009, 08:57 AM
FPKites
ZJjazzyJim
FPKites's Avatar
The double shear bar is a totally different design than the stock bar - you need the conversion bracket (drop bracket). Not to be confused with a rear trackbar bracket, which excels at breaking the mount.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
Spring hitting the IRO trac bar bracket. -cAcHe- ZJ Grand Cherokee Forum 61 01-14-2009 11:24 AM
tru-trac question sparkyB34 ZJ Grand Cherokee Forum 2 08-24-2008 01:56 PM
trac bar question mattwa311 ZJ Grand Cherokee Forum 2 04-11-2007 12:38 PM
trac-loc question???? titanic89 ZJ Grand Cherokee Forum 1 08-22-2006 04:49 PM
OME SS and Kevins front trac bar and rear bracket install Nick ZJ ZJ Grand Cherokee Forum 3 04-19-2006 08:08 PM
