dw - JeepForum.com
post #1 of 2 Old 10-13-2013, 12:35 PM Thread Starter
nnzaayer
dw
With a 3" lift can stock flca work. The ones with the lift are bent really bad. Have weld new brkts on axle, but was wondering if stock control arms would work. Also how would you go about setting the castor angle. I measured the stock ca anf the ones that came ofg. Thetes only like a half inch difference in length.
nnzaayer is offline
post #2 of 2 Old 10-13-2013, 01:10 PM
PolkaPower
Stock arms will work with 3. I wouldn't go more tan that. The cam bolts on the stock arms will give a little bit of adjustment but it may or may not be enough to get the pinon angle correct. Every zj is different so it may work for some but others may need sad least upper or lower adjustables.
PolkaPower is offline
