Durango Steering Box Writeup - Page 2 - JeepForum.com
post #16 of 29 Old 01-21-2007, 08:27 PM Thread Starter
gunthagunth
gunthagunth's Avatar
The long arms are a big help. What are you running as far as caster? I have my antisway bars beefed up with addcos. That is a big help, if not at this height level the stock bar takes a big load and flexes easily. I believe with it (antisway bar) flexing down a road going at a high speed would allow the back end to swerve around on the coils, and bouncing would allow the trackbar to let the body move side to side above the axle. I drove behind the zj the other day down the highway and I could visually see the back end moving laterally back and fourth when hitting bumps in the road. I blame this on the rear trackbar angle, antiswaybar endlinks too short, and worn control arm bushings.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #17 of 29 Old 01-21-2007, 08:37 PM
CAHotRodBoy
I am running the stock sway bar and will upgrade to the Adcos. I had Teraflex disco's but I had to cut the lower mounts and reposition them for the tie and drag link. This moved them up and few inches and caused the sway bat ends to angle way up. I put the old ones back on and it seemed to help. I was going to cut down the Tera's but I'd have to take 3&1/2" out of them. I think this will make them very short and I'll have trouble disconnecting them. I guess I'll get then ew bars first and then see. Are the adco's available from KOR again? I know they were hard to get for a while
'95 ZJ 5.2 LTD, 3.5" RE + 2" pucks, 5.9 wheels with ProComp XTerrains 285/75-16, CV drive shaft, KOR sliderz, adj track bar (front & rear), skid plate, rad support, OME steering stabilizer, JKS adjustable LCAs & UCAs, MX6 shocks, 4.56's, OX Locker in front, Detroit locker with 30 spline axles in rear, Carbon fiber cowl induction hood, Adco's w/custom disco mounts, DOM tube tie rod & drag link w/spherical rod ends.
'05 Avalanche 2500 4X4, 8.1/496, 4.10 gears, 6" CST lift, 315/70-17's on H2 rims.
CAHotRodBoy is offline
post #18 of 29 Old 01-22-2007, 07:11 PM Thread Starter
gunthagunth
Originally Posted by gunthagunth
Swapped in a waggy box today. Out of a 83 wagoneer 360. Everything bolted up proper until I got to tightening down the pitman arms 1 5/16" nut. Apparently it is a different thread count or something because the ZJ nut would not thread on. So I had to disassemble everything again and I swapped in the stock box again.
Come to find out advanced auto sold me another bad box. The pinion nut is fine, and the threads were trashed all the way up the shaft. I didnt notice it yeseterday due to aggravation. I brought the beating stick with me and they took the waggy box back full refund, then they took my zj box as a core after I told them that it is what they are getting, and they gave me a new durango box. I also picked up a new power steering pump and exchanged my SS's for new. Everything is installed and it runs great. Got about a inch of snow tonite so I was testing out how bad the baja claws are on ice. After some doughnuts I found that my throttle cable is still sticking . I may replace the cable to get it out of the picture but I dont think thats the case.
post #19 of 29 Old 05-30-2009, 06:37 PM
rmm149
Good write up. Keep in mind, on the WJ you have to move the windshield washer reservoir out of the way to get to the 4 steering box bolts. You have to drop the stabilizer bar to get the reservoir out of the way.
I couldn't get the pitman are off on the vehicle. I had to put it in the vise and used puller, torch, and large hammer simultaneously.
rmm149 is offline
post #20 of 29 Old 07-16-2009, 08:13 PM
papa102498
Post has been slow for a little while so I thought I would ask for an update on how the new box is doing? Steering issues fixed? The reason I ask is I just bought a 98 ZJ 4.0 that has a junk stock box in it, wanders something terrible and everything is good except for play in the box. It's bone stock right now but will be on 35's in the future. No point in buying an OE box that will need to be upgraded later. What years and engine size Durangos will fit my 98 so I can order a new box for it?
papa102498 is offline
post #21 of 29 Old 07-17-2009, 03:50 AM
newfieZJ
I installed a waggy box . It is no different that the stock box except the 4 th bolt hole . Mine is crap , I don't like it . It has more play than the stock(rebuild) which will be going back in . The waggy is going back for a replacement under warranty and will remain in the box until the other grenades .
If your steering box isn't leaking from the output shaft , and has play , follow the instructions for the bench adjustments before wasting money on a new box http://dodgeram.info/tsb/1997/19-10-97.htm
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #22 of 29 Old 07-17-2009, 04:16 AM
Colorado 5.9
Colorado 5.9's Avatar
Gunth has not post it in almost a year here. I wonder what happened to him.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #23 of 29 Old 12-09-2009, 12:44 PM
Alheim
^ too bad. i thought the durango write-up was a good one. i'd like to know how the durango box worked out in the long run (feel, etc.) ...
'95 YJ 123bhp 4-banger powerhouse.
UPDATE: 2.5L ENGINE RETIRED; she was still running strong at 212,000mi.
4.0 swap in progress.
Alheim is offline
post #24 of 29 Old 02-26-2010, 04:36 PM Thread Starter
gunthagunth
Durango box is still holding up pretty good no issues with 35's. Everythings been great since the new box and currie currectlync steering. Been off the road for a year now though. Never figured out my sputtering issue. Bought a house and a tj so its been on the back burner. Should get it back on the road soon. I log in here every now and then to check pms but without being a member i only get 3 pms and theyre usually 1 bogus question and 2 from the mods about resigning membership.
post #25 of 29 Old 02-26-2010, 07:17 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Good to hear from you Gunth - don't be such a stranger
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #26 of 29 Old 02-26-2010, 07:59 PM
Greengc4x4
Stick around man! thats a good write up you did. We need more guys like you around here.
Greengc4x4 is offline
post #27 of 29 Old 02-26-2010, 09:00 PM
Spike300
Dont forget Durangos and Dakota are basically the same vehicle, a Durango is just a suv version. Im gonna do this since i got a half stirpped Dakota in the shed with a box. yay for me!
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #28 of 29 Old 04-30-2014, 04:36 PM
creepyd
Hi guys.
Will the durango box work on a 92' yj?
Just drove down from canada to a buddies in south cali and I need to do a LOT of work on my jeep. Figured I would do this replacement while I'm at it.
creepyd is offline
post #29 of 29 Old 05-01-2014, 09:16 AM
speedbucket
Yes it should, I threw a yj box in mine after I broke the Durango box
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
dodge durango steering box upgrade bigbluezj94 ZJ Grand Cherokee Forum 50 04-18-2011 04:55 PM
Napa numbers and prices for steering boxes, (Durango, etc.) moparman12 ZJ Grand Cherokee Forum 19 12-05-2008 03:26 PM
Durango steering box not going as planned mopar3389 ZJ Grand Cherokee Forum 3 07-29-2008 10:39 AM
Durango tie rod end on ZJ? mopar3389 ZJ Grand Cherokee Forum 1 07-19-2008 10:13 PM
Durango steering box or stock ZJ replacement? ZJ Limited ZJ Grand Cherokee Forum 12 08-29-2006 03:20 PM
