Durango air hat on 5.9 - Page 6 - JeepForum.com
post #76 of 233 Old 08-08-2012, 03:29 PM
ELMCZJ95
Originally Posted by PolkaPower View Post
I also found that using porch screening on the intake hose instead of a K&N flows even better and frees up that space where the filter used to be.
I also have a leprechaun that looks like this inside the TB for that extra get up and go.
I'll have to do this as well. Another thing you can do is mix salt water, sugar, and metal shavings in a 5 gallon gas can. Make sure its a 4:2.6:7 ratio. Next put it in the gas tank and run it until empty. The 3 ingredients will adhere to each other and bore out/polish your entire engine. It works much better than getting it done by a shop and cost about $15
Jeep Grand Wrangler Build Thread: http://www.jeepforum.com/forum/f13/jeep-grand-wrangler-build-1398775/#post13935376
ELMCZJ95 is offline
post #77 of 233 Old 08-08-2012, 03:32 PM Thread Starter
PolkaPower
I have heard about this. They call it nano technology or nano bore right?
PolkaPower is online now
post #78 of 233 Old 08-08-2012, 03:34 PM
ELMCZJ95
Correct, Nano Bore. I actually invented it, along with the Tin Foil Turbo System.
ELMCZJ95 is offline
post #79 of 233 Old 08-08-2012, 03:36 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Kolak's into mythical beast trafficking?
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #80 of 233 Old 08-08-2012, 03:38 PM Thread Starter
PolkaPower
post #81 of 233 Old 08-08-2012, 03:39 PM
ELMCZJ95
aol@kolak.com
ELMCZJ95 is offline
post #82 of 233 Old 08-08-2012, 04:25 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
WOT is hardcoded into the PCM.
HighLonesome is offline
post #83 of 233 Old 08-08-2012, 04:26 PM
tizzly
1994 ZJ
Wow. i need some of that
tizzly is offline
post #84 of 233 Old 08-08-2012, 04:38 PM Thread Starter
PolkaPower
WOT are you talking about?
post #85 of 233 Old 08-08-2012, 04:42 PM
tizzly
1994 ZJ
how much power will i get if i add bullet hole stickers?
tizzly is offline
post #86 of 233 Old 08-08-2012, 04:53 PM Thread Starter
PolkaPower
Ladies will throw themselves in your lap
post #87 of 233 Old 08-08-2012, 04:56 PM
Cameleer
I'm going to save you all a lot of money.
If you want better air flow into the intake manifold (kegger) just pull some of the vacuum lines from it, and you get instant HP.
For a cold air intake, try putting some dry ice in the air box, although your CO2 level my increase!
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #88 of 233 Old 08-08-2012, 04:57 PM
tizzly
1994 ZJ
OMG. im leaving now!! Life is gettin good, now just need to find the parking lot the weed wackers are parked so i can get my drifting on
tizzly is offline
post #89 of 233 Old 08-08-2012, 05:00 PM
tizzly
1994 ZJ
liquid nitrogen purge system- right in the TB. Maximize the performance
tizzly is offline
post #90 of 233 Old 08-08-2012, 06:33 PM
ELMCZJ95
Pour about 10 gallons of water to the jeep's throttle body while it is running, your jeep will then become steam powered and require no gas to drive it.
ELMCZJ95 is offline
Durango tie rod end on ZJ? mopar3389 ZJ Grand Cherokee Forum 1 07-19-2008 10:13 PM
Fed up with Durango - want to buy a Jeep GC; what to look for? ti_co ZJ Grand Cherokee Forum 2 08-25-2007 06:01 PM
Durango Headers on a 95 ZJ V8 AutomagicGSX ZJ Grand Cherokee Forum 1 02-15-2007 05:23 PM
Durango headers? DrEvil11417 ZJ Grand Cherokee Forum 1 01-21-2007 08:41 PM
WK vs Durango. you tell me. DSMjunkie ZJ Grand Cherokee Forum 49 03-30-2005 07:30 PM
