Durango air hat on 5.9 - Page 5 - JeepForum.com
post #61 of 233 Old 08-08-2012, 10:10 AM
moparrr07
More air flow, and then what? You don't have more fuel or a way to exhaust it.
well you do have more fuel, do you think the injectors are maxed out on a stock jeep
all im sayin is going to all the work to cut out the hood to clearence for a durango air hat is pointless, no better than the stock one,
in a case where you have a ported intake and headers, your next step is a throttle body, and why would you put an upgraded throttle body with a stock restrictive air hat?
as towards temperature, yes it is metal, no it doesnt get hot, as in you can touch it without burning yourself as long as you have it routed so the filter takes in flesh air
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #62 of 233 Old 08-08-2012, 10:32 AM
tizzly
1994 ZJ
The comp auto adjusts for the air which is marginal at best. If you upgrade the inside larger injectors better everything. That 4 in air hat is awesome for a race motor, thats bout all tho
tizzly is offline
post #63 of 233 Old 08-08-2012, 11:27 AM
Cameleer
I install a Spectre air hat and it stays very cool until the engine is shut down and everything under the hood heats up.
From my understanding the only gain will be at WOT where I'm seeing -3in Hg and sometimes -2in Hg inside the intake manifold.
I also have a custom 3" exhaust system which I understand is good for a 700hp engine, and also installed a performance ignition kit.
After spending $1000 for these upgrades, I can't honestly say that I have notice any more performance over the stock setup.
In the next year or two I will be rebuilding the engine and throwing on new heads, new cam, along with a few other items, and then it will all come together to make a difference.
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #64 of 233 Old 08-08-2012, 11:30 AM
tizzly
1994 ZJ
There ya go, thats going to blow you away, get some bad *** power under the hood
Just the top end can get you up over 500hp if done right
tizzly is offline
post #65 of 233 Old 08-08-2012, 01:39 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Your stock mopar computer won't give you more fuel because you have a different air intake.
Unless you are a magician.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #66 of 233 Old 08-08-2012, 01:43 PM
tizzly
1994 ZJ
Hunter
right- it just keeps it mixed right. the stock ones can be tuned up for a bit more performance through the pcm, not much to be gained from them tho
tizzly is offline
post #67 of 233 Old 08-08-2012, 02:16 PM
moparrr07
it does keep it mixed right, you give it more air, it matches with fuel, results you wont feel but it happens
post #68 of 233 Old 08-08-2012, 02:16 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Only with a performance computer not a chip.
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #69 of 233 Old 08-08-2012, 02:40 PM
moparrr07
well my short term AND long term fuel trim both float right at zero, its say its adding plenty of fuel,
post #70 of 233 Old 08-08-2012, 02:49 PM
ELMCZJ95
I installed a mini ice maker in my air box so that I get the coldest air possible.
Jeep Grand Wrangler Build Thread: http://www.jeepforum.com/forum/f13/jeep-grand-wrangler-build-1398775/#post13935376
ELMCZJ95 is offline
post #71 of 233 Old 08-08-2012, 03:13 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Did you use newb tech on the minifridge? 5hp increase at least.
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #72 of 233 Old 08-08-2012, 03:17 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The Durango SRT airhat with variable flow fuel injectors to include all advertising will net you 87.2 more hp and 90.6 more ftlbs torque. (I read this on JU).
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #73 of 233 Old 08-08-2012, 03:20 PM
ELMCZJ95
Take your throttle body off and bang it with a hammer. The dents create a triple expository intake characteristic (often seen in tornadoes and hurricanes) which allow you to run your engine without any oil, therefore decreasing weight and freeing up about eleventy hundred horsepower at 14 RPMs.
ELMCZJ95 is offline
post #74 of 233 Old 08-08-2012, 03:21 PM
ELMCZJ95
Exactly my point, I don't know why more people aren't doing this!
ELMCZJ95 is offline
post #75 of 233 Old 08-08-2012, 03:24 PM Thread Starter
PolkaPower
I also found that using porch screening on the intake hose instead of a K&N flows even better and frees up that space where the filter used to be.
I also have a leprechaun that looks like this inside the TB for that extra get up and go.
PolkaPower is online now
Durango tie rod end on ZJ? mopar3389 ZJ Grand Cherokee Forum 1 07-19-2008 10:13 PM
Fed up with Durango - want to buy a Jeep GC; what to look for? ti_co ZJ Grand Cherokee Forum 2 08-25-2007 06:01 PM
Durango Headers on a 95 ZJ V8 AutomagicGSX ZJ Grand Cherokee Forum 1 02-15-2007 05:23 PM
Durango headers? DrEvil11417 ZJ Grand Cherokee Forum 1 01-21-2007 08:41 PM
WK vs Durango. you tell me. DSMjunkie ZJ Grand Cherokee Forum 49 03-30-2005 07:30 PM
