Durango air hat on 5.9 - Page 4 - JeepForum.com
post #46 of 233 Old 08-05-2012, 11:45 PM
vonericsen
Just thought I would bump this...I removed my k&n earlier today and did this mod. No noticeable difference between the two...now I gotta figure out what to do with the k&n....
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #47 of 233 Old 08-06-2012, 08:39 AM Thread Starter
PolkaPower
Wind chime?
PolkaPower is online now
post #48 of 233 Old 08-06-2012, 06:31 PM
vonericsen
Lol. If I can't sell it, that may be what it becomes...
post #49 of 233 Old 08-06-2012, 08:13 PM
Kevinyj95
It came off a 1998 - 99 dodge durango or dakota 5.2 or 5.9. I managed to hunt one down to investigate. Looks like a good mod. I will have to try it on my next stop by the JY. Thanks again PolkaPower.
Kevinyj95 is offline
post #50 of 233 Old 08-06-2012, 08:17 PM Thread Starter
PolkaPower
post #51 of 233 Old 08-08-2012, 12:55 AM
zachjf
Dont forget to get the mounting stud and hose with it, if your JY is anything like mine they sell it all as one complete piece if the stuff is still attached, that and they'll charge you the same price for just the air hat itself
Needs parts?
PM
or
zachjf is offline
post #52 of 233 Old 08-08-2012, 01:49 AM
moparrr07
http://store.spectreperformance.com/...499/2231.0.1.1
i use one of these, $100 675cfm no hood clearance issues,
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #53 of 233 Old 08-08-2012, 04:58 AM
tizzly
1994 ZJ
wow. 20 times less for a plastic one from the jy. i know what im doing
tizzly is offline
post #54 of 233 Old 08-08-2012, 08:22 AM
moparrr07
well its drop in, and it doesnt look like the durango one flows all that well having the bracing still in the way, not to mention the spectre is a 4 inch inlet and the durango is just stock
post #55 of 233 Old 08-08-2012, 08:47 AM
tizzly
1994 ZJ
But a properly set up 3 in is more than eunough flow for a 5.9 or 5.2 with stock internals. Upgrade the heads, cam and manifolds before going to a 4 in intake inlet
tizzly is offline
post #56 of 233 Old 08-08-2012, 09:02 AM
moparrr07
well a home cleaned up throttle body flows 600 some cfm, and this 4 inch air hat flows 675 cfm at 4 inches, ill let you decide
post #57 of 233 Old 08-08-2012, 09:53 AM Thread Starter
PolkaPower
What is that? A metal air heater?
post #58 of 233 Old 08-08-2012, 09:59 AM
tizzly
1994 ZJ
Just cause it alows that much air through does not mean the engine uses that much air. Cold air works by putting dense air into the engine thus reading lean for a split sec and the pcm adjusts and adds a tiny fraction more fuel. So it aint about size in tjis case. This is y I said upgrade tje internals and make the engine pull in more and tjat 4 in pipe might be worth the 100 dollars
tizzly is offline
post #59 of 233 Old 08-08-2012, 09:59 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
More air flow, and then what? You don't have more fuel or a way to exhaust it.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #60 of 233 Old 08-08-2012, 10:01 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
That's like having a 7 inch longarm lift, dana 60s, lockers and 30 x 9.50 15 MTs.
So, is there a plan for after you suck in more air?
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
Durango tie rod end on ZJ? mopar3389 ZJ Grand Cherokee Forum 1 07-19-2008 10:13 PM
Fed up with Durango - want to buy a Jeep GC; what to look for? ti_co ZJ Grand Cherokee Forum 2 08-25-2007 06:01 PM
Durango Headers on a 95 ZJ V8 AutomagicGSX ZJ Grand Cherokee Forum 1 02-15-2007 05:23 PM
Durango headers? DrEvil11417 ZJ Grand Cherokee Forum 1 01-21-2007 08:41 PM
WK vs Durango. you tell me. DSMjunkie ZJ Grand Cherokee Forum 49 03-30-2005 07:30 PM
