Durango air hat on 5.9 - Page 2 - JeepForum.com
post #16 of 233 Old 01-16-2012, 11:48 AM
RedneckZJ
just curious. how close was it with just trimming the cloth hood lining or whatever it is
'96 ZJ Orvis 5.2L (Mossy Oak Edit.)- UC+2" BB, Thrush Turbo, 2 12s, Lots Of Stickers
You drive a tj, we drive a zj. We have more power while you get more shower. We get the v8 while you get there too late. You have 2 doors well, we have 2 more. Ours costs a grand while yours has a price we cant stand.
RedneckZJ is offline
post #17 of 233 Old 01-16-2012, 11:55 AM Thread Starter
PolkaPower
Not close. The fabric wasn't the issue, it's the bracing. The hood was bent up when I closed it before trimming.
PolkaPower is online now
post #18 of 233 Old 01-16-2012, 11:57 AM
RedneckZJ
ah ok. looks like itll allow a lot more air flow
post #19 of 233 Old 01-16-2012, 12:09 PM Thread Starter
PolkaPower
We will see. I am going to Lowes in a few minutes to find some plumbing.
post #20 of 233 Old 01-16-2012, 02:37 PM
Eric1080
1978 J-Series Truck
its a great mod. did it to my 5.2. didnt even trim the hood brace. hood is slightly bowed. deeper sound on acceleration. actaully sounds like a magnum. i got about 1 mpg better as well and i think better acceleration. used spectre flex intake hose from autozone.
Eric1080 is offline
post #21 of 233 Old 01-16-2012, 02:45 PM
Exdecuk
Are these air hats easily available & if so what $$$ are we looking at?
A man will pay $2 for a $1 item he needs.
A woman will pay $1 for a $2 item that she doesn't need but it's on sale.
Exdecuk is offline
post #22 of 233 Old 01-16-2012, 02:47 PM Thread Starter
PolkaPower
I just picked up the same hose and coupler. I didn't want it touching the hood because the engine moves all the time. I paid ten bucks for he air hat at the junk yard off of a Dodge Durango.
post #23 of 233 Old 01-16-2012, 02:53 PM
Exdecuk
Just realised i have an M1 manifold on mine with a 52mm Holley TB & FIPK & space is really tight under there, you can see where the existing air hat is leaving a fair old mark on the insulation so one of these may be just too much even with some cutting. I have another 9er hood which i will be modifying soon so then it will definitely all fit
Exdecuk is offline
post #24 of 233 Old 01-16-2012, 03:03 PM Thread Starter
PolkaPower
Yea, isn't the M1 taller than the kegger?
post #25 of 233 Old 01-16-2012, 03:40 PM Thread Starter
PolkaPower
Ok it's all done and hooked up. I really don't think it's going to make a difference if I go through the trouble of grinding those tabs off to angle the air hat. It would look better though but this actually works better because the hose fits in a part of the hood where there is space. If the hat was turned towards the intake box then it would again hit a lower portion of the hood bracing.
post #26 of 233 Old 01-16-2012, 04:10 PM Thread Starter
PolkaPower
Just took it for a spin and there is a slight difference. Feels like it pulls a little harder through the gears and takes less effort to get it going from a stop. There is a slight whistle now. I also have a modded TB.
post #27 of 233 Old 01-16-2012, 04:39 PM
Fishhead
Did you plug that hole in the front of the hat where a hose connects? Maybe that is where the whistling is coming from, I would plug it up, dirt/dust will be sucking in there.
Fishhead is offline
post #28 of 233 Old 01-16-2012, 04:53 PM Thread Starter
PolkaPower
I used the lid from my wife's chap stick to cap the breather inlet. It's on there so tight I can't pull it off. That solution caused another problem that I wasn't able to fix so easily. She is pissed off that her chap stick is lidless. It sounds a bit like the K&N I had on my old ZJ.
post #29 of 233 Old 01-16-2012, 08:48 PM
extrememarine
1994 ZJ
M1
Directions from Mopar state M1 MPI intake puts TB at same elevation above engine / below hood as OEM intake (aka kegger) - If there's a difference, it's less than mm's - I can't tell a difference on mine.
Semper Fi,
Extrememarine
extrememarine is offline
post #30 of 233 Old 01-17-2012, 08:19 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Nice cheap mod! You should reset the computer maybe.
whistle is usually a leak
HighLonesome is offline
Durango tie rod end on ZJ? mopar3389 ZJ Grand Cherokee Forum 1 07-19-2008 10:13 PM
Fed up with Durango - want to buy a Jeep GC; what to look for? ti_co ZJ Grand Cherokee Forum 2 08-25-2007 06:01 PM
Durango Headers on a 95 ZJ V8 AutomagicGSX ZJ Grand Cherokee Forum 1 02-15-2007 05:23 PM
Durango headers? DrEvil11417 ZJ Grand Cherokee Forum 1 01-21-2007 08:41 PM
WK vs Durango. you tell me. DSMjunkie ZJ Grand Cherokee Forum 49 03-30-2005 07:30 PM
