Durango Air Hat - Page 2 - JeepForum.com
post #16 of 29 Old 08-13-2013, 01:42 PM Thread Starter
KoltenZJ
I'm fairly new to this whole modding world and such, I don't understand a lot of it....and where would I pick up an elbow for it?
*1997 Jeep Grand Cherokee Limited
3.5" Rough Counrty Lift, 265 75 r16 BF Goodrich All Terrain TA KO Tires
Check out my build thread!
KoltenZJ is offline
post #17 of 29 Old 08-13-2013, 05:19 PM Thread Starter
KoltenZJ
I picked up a Durango air hat, the intake tube is too loose and the air hat needs an elbow to reach the tube
KoltenZJ is offline
post #18 of 29 Old 08-13-2013, 06:14 PM
PolkaPower
Use the stock tube or get a tube from pepboys. This is not rocket science, you can do it.
PolkaPower is offline
post #19 of 29 Old 08-13-2013, 06:24 PM
kg6mov
Hears the voices
kg6mov's Avatar
You might think of just doing the cowl filter relocate at the same time.
http://www.jeepforum.com/forum/f13/c...intake-894400/
kg6mov is offline
post #20 of 29 Old 08-13-2013, 08:55 PM Thread Starter
KoltenZJ
The stock tube doesn't fit. And like I said I'm new to all this...sorry I probably sound annoying...
KoltenZJ is offline
post #21 of 29 Old 08-13-2013, 09:34 PM
PolkaPower
Na you are fine. I think someone on here used the stock tubing. I didn't take a second look for myself on mine because I had already got the 3" flex tube from Pep boys.
post #22 of 29 Old 08-13-2013, 10:56 PM
zachjf
I used both the Durango (Dakota) tube and my stock tube and mated them together to make it work, still holding up today
Needs parts?
PM
or
zachjf is offline
post #23 of 29 Old 08-14-2013, 12:18 AM Thread Starter
KoltenZJ
Hmm, so 3" flex tubing, and that would fit the air hat as well as the bit that holds the air filter? Could you link me to the one you used, and did it work without an elbow?
KoltenZJ is offline
post #24 of 29 Old 08-14-2013, 01:28 AM
zachjf
Here..... http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_air-intake-kit-flexible-duct-spectre_22906020-p
I found that drunk so you have no excuse!
Needs parts?
PM
or
zachjf is offline
post #25 of 29 Old 08-14-2013, 01:31 AM Thread Starter
KoltenZJ
Thanks Zach
KoltenZJ is offline
post #26 of 29 Old 08-14-2013, 04:11 PM Thread Starter
KoltenZJ
Got it installed, just need to trim now and I'll be good to go! Polka what did you use to cut away the metal under the insulation? And thank you everyone for your help!
KoltenZJ is offline
post #27 of 29 Old 08-14-2013, 04:57 PM
PolkaPower
I used a Dremmel with a metal cutting wheel. I was impatient and I didn't do it as neat as I could have.
If you want to do a really nice job then take the hood off.
post #28 of 29 Old 08-14-2013, 07:36 PM
zachjf
taking the hood off made it super easy to keep the cuts clean and to smooth everything out plus its only 4 bolts, maybe 3 min to get the hood off
Needs parts?
PM
or
zachjf is offline
post #29 of 29 Old 08-15-2013, 12:06 AM Thread Starter
KoltenZJ
I did it all with the hood on, used a grinder. Didn't come out to bad. Take a look at my build thread to see some pics! Thanks you all for help! I love the air hat, runs much nicer.
KoltenZJ is offline
