Durango Air Hat - JeepForum.com
post #1 of 29 Old 08-13-2013, 12:03 PM Thread Starter
KoltenZJ
Durango Air Hat
Other than getting the air hat from a jy what would need to be done for it? Would I need to just put it on and voila, or do trimming and cutting things etc?
I have a 97 5.2
*1997 Jeep Grand Cherokee Limited
3.5" Rough Counrty Lift, 265 75 r16 BF Goodrich All Terrain TA KO Tires
Check out my build thread!
KoltenZJ is offline
post #2 of 29 Old 08-13-2013, 12:30 PM
zj97ltd
Pretty sure you have to trim the underside of your hood (bracing) or it won't close. It's quite a bit taller than stock.
zj97ltd is offline
post #3 of 29 Old 08-13-2013, 12:36 PM Thread Starter
KoltenZJ
That's not bad, I was expecting to have to do a bit more than that.
KoltenZJ is offline
post #4 of 29 Old 08-13-2013, 12:46 PM
zj97ltd
No I think that's it. If you search I think there's a couple write ups about it.
zj97ltd is offline
post #5 of 29 Old 08-13-2013, 12:48 PM Thread Starter
KoltenZJ
I searched on here but only found things for the 5.9 and the wranglers.
KoltenZJ is offline
post #6 of 29 Old 08-13-2013, 12:54 PM
Myusername1674
Like you said about the 5.9, it should be the same, but you may not even have to do as much since the 5.9 is a little bigger. Here's that 5.9 Link Though it might be helpful.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #7 of 29 Old 08-13-2013, 12:55 PM Thread Starter
KoltenZJ
Awesome thanks bud!
KoltenZJ is offline
post #8 of 29 Old 08-13-2013, 12:57 PM
zj97ltd
Should be the same intake and everything. If you put a 5.2 & 5.9 long block side by side most couldn't tell them apart.
zj97ltd is offline
post #9 of 29 Old 08-13-2013, 01:07 PM
PolkaPower
The 5.9 and 5.9 block is the exact same. Only internals are different.
http://www.jeepforum.com/forum/f13/d...5-9-a-1315001/
PolkaPower is online now
post #10 of 29 Old 08-13-2013, 01:11 PM
dylantheheeler
Usually the 5.9 is the same as the 5.9. Except in some rare cases.
Just messin' with ya
Sent from AutoGuide.com Free App
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline
post #11 of 29 Old 08-13-2013, 01:16 PM
PolkaPower
I was under the impression that the 5.9 was the same as the 5.9 except for the 5.2 which is like a 5.9 but in most cases like a 5.2 bring on the vodlka
post #12 of 29 Old 08-13-2013, 01:21 PM
zachjf
I'll say this, if you try to clock the air hat twards the airbox opening like I did it in the 5.9 thread, your gonna have major clearance issues once you replace your motor mounts. Basically I'm going to have to move my battery to where the airbox is now so I can flip the airhat around and point it the other way to put the fat side at the rear plus fab up some sort of cold air setup so as to not be sucking up engine heat. At this point its either that or pick up one of the Spectre air hats summit sells
Needs parts?
PM
or
zachjf is offline
post #13 of 29 Old 08-13-2013, 01:23 PM
PolkaPower
I didn't angle mine as you know but I did notice that the motor sat up much higher after the mm repair. I put a couple washers under the hood bolts for a little extra room. You know. More cushion for the pushin.
post #14 of 29 Old 08-13-2013, 01:24 PM Thread Starter
KoltenZJ
How should I angle it then?
KoltenZJ is offline
post #15 of 29 Old 08-13-2013, 01:40 PM
PolkaPower
Sounds like you didn't look at the link I posted.
