dumb question.. cant stop thinking about it - JeepForum.com
post #1 of 20 Old 07-05-2011, 09:33 PM Thread Starter
worsrider4047
ok so i was overheating and it was on and off so i thought it was the thermostat, bought and installed a new one, problem is, its still doing it, i installed the spring down which i believe is right but when i think about it, it seems wrong cause doesnt the coolant come from the top end after the thermostat opens? which it opens downwards?
i dont get how that works lol shouldnt the pressure push up to open
worsrider4047 is offline
post #2 of 20 Old 07-05-2011, 09:37 PM
little_Jeep
The spring end goes into the block of the engine. When thermostat opens, hot coolant is allowed to flow from the engine into the top radiator hose and to the radiator....as the hot coolant travels down thru the radiator, it is cooled and then passed thru the lower radiator hose and back thru the engine.
little_Jeep is offline
post #3 of 20 Old 07-05-2011, 09:41 PM Thread Starter
worsrider4047
yea i know that lol i just confused on how it opens down, hot coolant should expand to push open not suck down to open, idk maybe im just crazy but its stuck in my head and i cant stop thinking about it
post #4 of 20 Old 07-05-2011, 10:01 PM
little_Jeep
I understand what you are saying. However, in real World, the flap pulls downward to open thermostat.
post #5 of 20 Old 07-06-2011, 12:45 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
It opens from the bimetal strip, not pressure.
ratmonkey is offline
post #6 of 20 Old 07-06-2011, 01:10 AM
jnicewan
The cylinder shaped bulb just inside the spring has a special wax in it. When the wax gets heated to a certain temperature it causes expansion to push a piston which is pinned to the top the thermostat. This forces the bulb down, which is attached to the valve, therefore allowing coolant to open. They do not open due to pressure or expansion of the coolant.
This pics shows what an open vs shut thermostat looks like. Notice how the bulb part has moved down when the valve is open.
jnicewan is offline
post #7 of 20 Old 07-06-2011, 08:43 AM
Foundrydude
Shift your thinking toward the clutch fan for intermittent overheating.
Foundrydude is offline
post #8 of 20 Old 07-06-2011, 08:57 AM
little_Jeep
I always install "Fail Safe" thermostats... they cost a little more, but if your vehicle's coolant overheats, the "Fail Safe" thermostat freezes in the open postion, where as a normal thermostat will freeze in the closed postion when overheated.
post #9 of 20 Old 07-06-2011, 01:06 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
My friend who has a gmc might argue the "fail safe" route, he said they ought to make a fail safe for the fail safe lol. I've seen several makes for the I6 and always wound up doing the dealer thing. One difference I noted was the little bypass mechanism in the dealer stat. Don't know exactly what it does but some parts houses will sell one that doesn't have it. The duralast {what a name} does have a similar mechanism. Is it an air bleed after draining the system?
coralman is offline
post #10 of 20 Old 07-06-2011, 05:57 PM
Bishop3854
if your talking about the lil hole with the metal piece in it then yes, it help break up air pockets and makes filling alot easier.
Bishop3854 is offline
post #11 of 20 Old 07-07-2011, 12:25 PM
tcar
1. Pressure has NOTHING to do with it... as everyone said, it's temperature. Does not matter where the spring is.
2. Only use a Mopar thermostat from the dealer. Most aftermarket t-stats don't work properly in the Jeep there are a couple brands (one that used to be OK isn't anymore), but to be safe, buy a mopar.
Go buy a Haynes Manual.
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #12 of 20 Old 07-07-2011, 12:29 PM
little_Jeep
Say What?
post #13 of 20 Old 07-07-2011, 12:41 PM
tcar
What.
The factory t-stat has a small valve on the side that cheap aftermarket stats don't have.
98 5.9 Platinum
95 Limited V8
tcar is offline
post #14 of 20 Old 07-10-2011, 11:48 AM
AAA
What?
AAA is offline
post #15 of 20 Old 07-10-2011, 12:03 PM
TallyZJ
What.
Some t-stats had a hole in the restrictor plate to help eliminate trapped air. This hole was to be installed where it was at the top. Had nothing to do with cooling or the operation of the t-stat itself. I remember this hole on the t-stats for the Cherokee but not the Grand Cherokee.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
Dumb Question gem300wby ZJ Grand Cherokee Forum 12 03-24-2010 03:38 PM
maybe a dumb question?? bigmike ZJ Grand Cherokee Forum 2 01-27-2010 02:47 AM
Dumb Suspension Question Or Dumb Owner AaronJames ZJ Grand Cherokee Forum 8 04-06-2009 11:47 PM
dumb question, front bump stop removal Dayzz ZJ Grand Cherokee Forum 6 01-25-2009 09:53 PM
Dumb Question but... 1997grandtazz ZJ Grand Cherokee Forum 2 02-04-2006 06:20 PM
