Dual Exhaust???? - JeepForum.com
post #1 of 9 Old 10-18-2004, 03:31 PM Thread Starter
allholdem
Dual Exhaust????
I'm looking to replace my ZJ exhaust and I wanted to know if there is any dual exhuast systems.. I really like the look of the exhaust tips on both sides of the car, but have yet to find something made for a 94 ZJ.
allholdem is offline
post #2 of 9 Old 10-18-2004, 05:12 PM
Meerkat
4x4 or 2x4?
Your best bet will probably be to run a single large pipe then split into two smaller pipes at the fuel tank.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 9 Old 10-18-2004, 05:54 PM Thread Starter
allholdem
I have a 5.2 v8 4x4, any suggestions on a setup that comes ready to install like that.
post #4 of 9 Old 10-18-2004, 06:08 PM
Meerkat
None that I'm aware of..
You could contact Nick (kolak@aol.com) and get the 2.5 inch exhaust system, and have your local welding shop weld it up and manufacture a 'Y' at the gas tank to split the system and make the second exhaust tip.
HTH
Warren
Meerkat is offline
post #5 of 9 Old 10-18-2004, 09:58 PM
Buddha_Kip
Buddha_Kip's Avatar
just run separate pipes from each bank and have them exit just before the rear tires...can use a crossover pipe if you'd like, but it really isn't necessary. This would be the cheapest route you could go.
2000 WJ Limited - 2.5" Rusty's springs § WAAG 1-piece front brush guard § custom built WAAG nerf bars § PIAA 580 lighting § Custom Paint § One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step §
1986.5 Porsche 928S - 18" Moda MD1 § Autothority Chips § Rear Muffler Bypass § Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #6 of 9 Old 10-18-2004, 10:58 PM
Meerkat
That won't work very well in a 4x4. You run into interference issues with the front drive shaft.
Also, a crossover pipe isn't necessary, but it's purpose is to help keep the back pressure balanced on both banks. Further, it's location directly affects the torque curve. It's been an awful lot of years since I messed with duals, but if I remember correctly, the closer the crossover tube is to the manifold the lower in the rpm range you feel the torque.
Warren
Meerkat is offline
post #7 of 9 Old 10-19-2004, 08:58 AM
KingZeke
KingZeke's Avatar
I have looked into this and none of the muffler shops I have talked to recommend this on a grand. About 80% told me that there was not enough room really to run a true dual exhaust and it would help the jeep perform any better.
1997 Jeep Grand Cherokee Laredo
2 Inch Budget Boost from Rubicon Express
31 Inch Tires, Shaved front facia
IMCO Exhaust
Almighty 2" BB Club Member # 38
KingZeke is offline
post #8 of 9 Old 10-19-2004, 06:01 PM
shookwell
shookwell's Avatar
Why would you want a dual exhaust? If it's a 5.2 it doesn't need more than 2.5" piping, better to spend your money on some headers and mandrel bent exhaust.
BTW - it can be done, it's just not easy. KRC's project jeep has a true dual 3" exhaust. But that jeep is running a 5.9 stroked to 408 with nitrous.
http://www.krcperformance.com/newcontent/Jeep.html
shookwell is offline
post #9 of 9 Old 10-19-2004, 06:18 PM
GreenCherokee85
I have true duel on my jeep but like wvd said it would interfere with the front driveshaft. The reason mine is fine is because i converted mine to rear wheel drive. It was prob a dumb move but i like the exhaust coming out from the sides of mine. It all up to you on wut you would like to do. Most likely if there is a custom exhaust shop around they could do it but ur prob better off getting a nice set of headers first.
GreenCherokee85 is offline
dual exhaust? redneckwithajeep ZJ Grand Cherokee Forum 7 04-11-2010 04:09 PM
Dual Exhaust on a Wk pyscovette WK Grand Cherokee & XK Commander Forum 7 12-12-2008 11:37 PM
dual exhaust mxracer511 ZJ Grand Cherokee Forum 7 10-30-2006 01:27 PM
Dual exhaust on a 5.2 ????? truetuner ZJ Grand Cherokee Forum 8 06-26-2006 01:33 PM
dual exhaust on a 4.0L Ned97sahara ZJ Grand Cherokee Forum 22 07-22-2005 04:31 PM
