DTC Code P0456 is intermittent - Is this a serious issue? - JeepForum.com
post #1 of 9 Old 10-20-2008, 08:21 AM Thread Starter
Saxidani
Hi,
This will be my first post here on the jeepforum and I hope that someone will be able to help me with this issue. I have a 2004 Jeep Grand Cherokee Laredo Freedom Edition that has 64,000 miles on it.
A few weeks ago while driving, my check engine light came on. (I had just put gas in the vehicle the night before). I took it to the local auto parts store and they plugged in the OBD II sensor and it gave the code P0456 (EVAP Monitor Leak Detected - Very Small)
My dad said that it could have been just bad gas or something so I waited a few days... it did go away... but then came back again, and is still on now.
Could this have anything to do with the 10% ethanol mix in gas now? I mean... cars arent designed to run with that in there really are they?
I went online and searched the code for my jeep and I found a TSB bulletin for "fake p0456 codes" on the 2002 and 2003 models of Jeep Grand Cherokee...
Has anyone else had this code? Is it possible to fix it without bringing it to the dealership?
thanks in advance!
Saxidani is offline
post #2 of 9 Old 11-27-2008, 10:15 PM
daddyfitz
well....
Hey man I've been having the same problem with my 03 tj and have talked to a few people and most say its the gas cap. I've cleared the code twice now and find it hard to believe that this is the problem but can't offer a better explaination. I'll keep you posted in case I get a better fix.
daddyfitz is offline
post #3 of 9 Old 11-27-2008, 11:35 PM
ksturgio
Well it often is this gas cap failing to seal. Usually the gasket cracks. Or the rubber sections between the meetal evac lines are heat rotting. The easiest fix is to buy a new gas cap. I've heard even from the stealership it's like $15. I would start there. If that isn't it I would inspect as much of the evac system for cracks or leaks as possible. If you are still having a problem take it to a shop you trust and have them perform a smoke test. I paid $127 for the test on my 01 xj last month. They fixed the leak for free just using some rubber hose. Good luck a real stubborn problem that is pretty common. I couldn't pass an emissions test because of this error code thanks to the greenie commies in washington and cali.
ksturgio is offline
post #4 of 9 Old 01-22-2012, 11:31 AM
Kolkster
2004 FSJ Cherokee
I have an 04 GC Special Edition and got this code about 2 weeks ago, had it read and reset, then it came back about a week later. From my local autozone, the readout "probable causes" are (1) fuel cap, (2) Evap cannister broke or hose leak, (3) purge solednoid defective, (4) vacuum leak at engine.
I'm approaching this methodically. First I'm going to discount the fuel cap by wrapping saran wrap around the cap before screwing it in to eliminate the cap as a possibility. I'm in the process of checking this now. Next I'll check for leaks, not sure how to easily do this, any suggestions??
Kolkster is offline
post #5 of 9 Old 04-14-2012, 10:39 AM
dusterdude
If the az guy cleared the code for you,next time you see him tell him its against federal law to clear codes,now ill admit most folks dont care about it,its still against the law
dusterdude is offline
post #6 of 9 Old 05-30-2015, 04:17 PM
Jmetsdad
clearing codes
Mr.dusterdude,
I hate to inform you of this, but it is not against the law to erase code from an auto if you are troubleshooting a problem. Besides if there is a problem it will come back as soon as the key is turned again.
I am facing the same problem with a 2004 GC, new gas cap ( we bought a locking one)and I still have not found any other problems that could be causing the code to show up.
Jmetsdad is offline
post #7 of 9 Old 05-30-2015, 04:40 PM
AVR2
Yeah, bunch of wimps, wanting to breathe less polluted air...
AVR2 is offline
post #8 of 9 Old 05-30-2015, 04:45 PM
kg6mov
Hears the voices
kg6mov's Avatar
Dusterdudes comment is three years dead, the rest of the thread is 7 years dead.
kg6mov is online now
post #9 of 9 Old 05-30-2015, 05:24 PM
marduksenforcer
Old dead threads are fun aren't they. Here ill try, if it aint the gas cap, its the leak detection pump. Have had this recurring code on my kj for 2 years and about 40xxx miles. It doesnt hurt a thing.
Ok next thread resurrection is located.........
-AJ
marduksenforcer is offline
Meh: Error code P0456... ptwelve ZJ Grand Cherokee Forum 9 09-30-2009 02:54 PM
P0456 Code, Erased but not gone... 01Limited45324 ZJ Grand Cherokee Forum 4 08-03-2009 01:48 PM
intermittent starting issue Tiggerrrrr ZJ Grand Cherokee Forum 10 10-23-2008 01:04 PM
P0456 - error code .. coudl seomeone do a search . looking for a specific post sanboy ZJ Grand Cherokee Forum 8 10-15-2006 01:04 PM
Intermittent drivability issue SRidley ZJ Grand Cherokee Forum 2 02-04-2005 10:37 AM
