drum to disc conversion - JeepForum.com
post #1 of 4 Old 05-11-2004, 10:56 AM Thread Starter
900Steve
anyone ever done or heard of this? granted most of the stopping power is already handled by the front discs, i just can't stand drum brakes!
-steve
900Steve is offline
post #2 of 4 Old 05-11-2004, 02:14 PM
97RedBird
2009 MK Compass
I can't remember the first year, but I know my 1996 GC laredo came with rear discs, and I believe all jeeps that year started to come standard with 4 wheel discs. You should be able to pick up new rotors and calipers at a auto store and get the rest at a auto salvage yard.
For everyone else to help you even more you may want to tell them what year of GC you have.
97RedBird is offline
post #3 of 4 Old 05-11-2004, 07:13 PM
Saleen4971
1994 limiteds started rear disc. 1995 and up, everythign had rear disc. i was interested in doing the swap as well. i woudl think youd only need the master cylinder, ABS pump and computer, rotor, caliper, proportioning valve, and mounts from a rear disc ZJ. anythign i missed?
1998 5.9 Limited
ET: 14.3@94MPH
Engine/Trans
- Full Kolak Exhaust (ML's FM70) - FIPK2 - APS 52mm TB - MSD Blaster SS - A3923's - Magnecor's - MP ECU - 180 robertshaw t-stat - Relocated IAT - E.H. M1 - B&M Trans Cooler
Susupension/Brakes
- Addco 1.25" Military front & 7/8" rear sways - Edelbrock IAS shocks - OME S.S - Stilens Front & Rear
Coming Soon :
Level10 Stage 3 46RE - WJ knuckle conversion
Saleen4971 is offline
post #4 of 4 Old 05-11-2004, 07:59 PM
Swamp Boy
Swamp Boy's Avatar
I did the disk swap on mine.. Found a 98 in the bone yard and pulled them off and they just bolted right to mine.. The only thing I had to change was the emergency brake cables..
Very simple...
Just another soccer moms Grocery getter....
Swamp Boy is offline
Drum to Disc Conversion? jordanhoff ZJ Grand Cherokee Forum 2 08-14-2009 09:47 PM
How to do a Rear drum to rear disc conversion CrazyDrivinJoe ZJ Grand Cherokee Forum 11 11-16-2008 11:33 AM
rear drum to disc conversion on a 94 zj with ABS CrazyDrivinJoe ZJ Grand Cherokee Forum 0 10-26-2008 04:25 PM
Drum to disc conversion using OEM products? Possible? SPL Tech ZJ Grand Cherokee Forum 5 08-12-2006 09:21 AM
'94 ZJ Drum to Disc Conversion? ShadMan ZJ Grand Cherokee Forum 9 10-04-2004 10:51 PM
