Driving without a sway bar? - JeepForum.com
post #1 of 15 Old 07-02-2013, 11:36 AM Thread Starter
BCrawford64
I've heard that driving without a sway bar is pretty sketchy. Is this true? The reason is that I had to replace my sway bar bushings, and endlink bushings. When I was trying to remove the nuts that hold the end links onto the sway bar they snapped off. I've tried to drive the end links out of the sway bar with a punch but they just wont come out. So just incase I get called back to work next week, I want to know if it's ok to drive without a swaybar and steering stabilizer.
BCrawford64 is offline
post #2 of 15 Old 07-02-2013, 11:38 AM
PolkaPower
I lost my disco pins and had to drive 40 miles on a windy desert highway with semi trucks flying past me. Felt like I was going to have to change my shorts after that.
PolkaPower is offline
post #3 of 15 Old 07-02-2013, 11:42 AM
moose27
I took my rear sway bar out a long time ago and its nothing. I barely see a difference. I always had a busted stablizer steering shock go out and drove with it for awhile and it was a slight rough but it was no biggy
Build: http://www.jeepforum.com/forum/f13/mooses-jeep-build-1456174/
moose27 is offline
post #4 of 15 Old 07-02-2013, 11:45 AM
coltman151
If its the front, don't even attempt it unless its an emergency. The sway bar is all that suppresses body roll on your jeep.
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
post #5 of 15 Old 07-02-2013, 11:52 AM
beaver2low
1994 ZJ
so driving with out the rear sway bar won't mess with drivabilility too bad
beaver2low is offline
post #6 of 15 Old 07-02-2013, 11:55 AM
WhiteOut
WhiteOut's Avatar
You can drive it, but you need to realize that you are going to be have a lot more body roll that you normally have. This means that you'll get pushed around more by semi trucks passing and you'll have to slow down a lot more in corners. I'd hit the junkyard and see if there is one there. Steering stabilizer is not needed.
WhiteOut is offline
post #7 of 15 Old 07-02-2013, 11:56 AM
WhiteOut
WhiteOut's Avatar
Don't bother taking it out to try and get more flex. It doesn't work that way.
WhiteOut is offline
post #8 of 15 Old 07-02-2013, 11:56 AM
exmilitary
I would not try it. The jeep get very tippsy. I have damaged the stabilizer links while driving and found it to be unstable while turning
exmilitary is offline
post #9 of 15 Old 07-02-2013, 12:00 PM
beaver2low
1994 ZJ
I got the sway bar in the rear its just not mounted to the body. I need to get the bolts to remount it. I bought the zj with it off.
post #10 of 15 Old 07-02-2013, 01:21 PM
JohnnyZJ
Make sure you have at least one sway bar hooked up. Front or rear who cares. Both off is going to lead you to Walmart shopping for new underpants after you crap yourself when the first semi you pass almost blows you off the road.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #11 of 15 Old 07-02-2013, 07:32 PM
AlphaLorde
I'm rebuilding my jks discos and removed my entire sway bar. Been like that for a while.
Just realize you dont have a front sway bar and drive accordingly.
And OP you are not lifted, it wont be as noticeable as a lifted zj.
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #12 of 15 Old 07-02-2013, 08:42 PM Thread Starter
BCrawford64
Cool. Thanks for the info guys. I don't drive on the highway much so I guess I'll just have to try it out.
post #13 of 15 Old 07-02-2013, 10:40 PM
SchizophrenicMC
2016 JK Wrangler
This gets asked about once a week.
The short answer is, yes, you can drive with your swaybar off. The longer answer is, no, you won't be safe driving that way. Your vehicle's center of gravity is higher than the halfway point up it, so it wants to roll very badly, and without the anti-sway bars doing their thing to prevent roll, you're playing with fire whenever you drive at any speed with the sway bars defeated. In a pinch, you can do it if you drive very white-knuckle carefully. I would suggest finding a new bushing and mount ASAP and getting that on there because you're not gonna have a good time driving with no anti-sways.
Signature rules are dumb
SchizophrenicMC is offline
post #14 of 15 Old 07-03-2013, 07:24 AM
ryanlawhon
just saying i have done it on a long armed grand for quite a while just because i need to finish up my end links. and i drive it day in and day out with out problems.ya it gets a good amount of body roll but its still driveable. and i have no sway bar front or rear for the time being
ryanlawhon is offline
post #15 of 15 Old 07-03-2013, 08:00 AM
Timo_90xj
Timo_90xj's Avatar
With the rear swaybar, you hardly notice any difference if it's disconnected and the front is not. Front discoed, you certainly notice a difference no matter if you're stock height or 5" lift.
Disconnected front swaybar on the road is a bit sctechy, and you notice it's missing almost anywhere you drive. Is it drivable? Yes. Is it safe? To some extent - just try avoiding quick manouvers. Would I keep the front disconnected for extended periods unless I had to? No. The longest I've driven my ZJ with the front disconnected was for around two weeks due to some work in the front I didn't have time to do. I drove my XJ I think almost through the whole winter (~5 months) with the front & rear disconnected, but they are a bit different story with the rear leafs. Then again, I also rolled my XJ with the front connected, so it really won't stop you from flipping the Jeep
***Under construction***
Timo_90xj is offline
