Driving Without a Driveshaft In The Rain - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Driving Without a Driveshaft In The Rain
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 07-02-2014, 01:38 PM   #1
elijahpr
Just wanted to warn all of you with bad VC couplers who are thinking about pulling your front driveshaft. I did this a week or so ago, and I didn't have any idea how bad it would make my ZJ drive in the rain! Tires were spinning out and the ground was barely wet. Not worth risking the damage by leaving it in until you do a TC swap or get a new VC, but just something to be aware of!
1998 Grand Cherokee TSi
3-inch Rough Country Lift
elijahpr is offline   Reply With Quote
Unread 07-02-2014, 01:52 PM   #2
94cherry
1994 ZJ
No offense but you must either have bad tires or don't know how to ease the gas pedal down when taking off from a stop. IMO The damage having a bad VC far out weighs what can happen in the rain if you don't know how to drive in 2wd.
Authority should derive from the consent of the governed, not from threat of force!
94cherry is offline   Reply With Quote
Unread 07-02-2014, 02:02 PM   #3
elijahpr
Tires are new as of last summer, so I don't think so. You may be right about having a heavy foot when moving from a stop sign, but it happens no matter how hard or lightly I hit it.
Unread 07-02-2014, 02:11 PM   #4
xcaliber81
1994 ZJ
New tires can still be junk.
Im indian my elders name is Jeep Grand Cherokee, I mean Chief Grand Cherokee. Quoted from Peter Griffin.
xcaliber81 is offline   Reply With Quote
Unread 07-02-2014, 02:14 PM   #5
marduksenforcer
I drove through a crap winter, with no front DS, crappy half bald tires, a shot suspension, and had not 1 single problem. Same goes for the rain.
-AJ
marduksenforcer is offline   Reply With Quote
Unread 07-02-2014, 02:20 PM   #6
kg6mov
Hears the voices
kg6mov's Avatar
You have a 4.0 though
Yes the V8's can be touchy and tail happy in 2wd if the road conditions aren't great, once you get used to it it's not bad though.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is offline   Reply With Quote
Unread 07-02-2014, 02:34 PM   #7
sebian
You also have to remember that in light rain, the roads can be far slicker than after a steady rain. The light rain only brings the oils in the road to the surface, where the steady rain can start washing those oils away, providing slightly improved traction. Just watch out for hydroplaning...
1995 ZJ 5.2L V8 318. 220,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline   Reply With Quote
Unread 07-02-2014, 02:39 PM   #8
jeepjeepster
Ive heard of people doing 360's in the 5.9 when they really didnt want to. Gotta take it easy when youre use to awd in a v8. More so with a limited slip.
And youre 100% correct about light rain. Ive slid several times in a light rain when i really shouldve have. Everyones leaky rear mains build up on the road haha.
1994 ZJ-I6 w/211,000 mi
1998 ZJ 5.9 w/64,800 mi Slate Black
2004 KJ w/85,000 mi
jeepjeepster is offline   Reply With Quote
Unread 07-02-2014, 02:50 PM   #9
PolkaPower
Roads are most slick right after it rains. Drive Iike a granny.
PolkaPower is offline   Reply With Quote
Unread 07-02-2014, 02:54 PM   #10
marduksenforcer
Good point, good point...
-AJ
Unread 07-02-2014, 03:20 PM   #11
elijahpr
I didn't know that about light rain and oils, good to know. Supposed to be a nasty thunderstorm tonight, so maybe I'll take her out and try not being so heavy on the gas on takeoffs.
As for the tires being the issue, they did fine with the driveshaft in when it rained. So chances are it's not those.
AJ, it's looking a lot like I'll be doing the same this winter
Unread 07-02-2014, 03:41 PM   #12
kg6mov
Hears the voices
kg6mov's Avatar
I did a 360 in my green one with a front driveshaft once. First rain in months and it had only sprinkled for a few minutes. I took a right onto a freeway ramp and the back end passed me.
The niner without the driveshaft and the crappy PO tires would spin tires all day at a light even on dry pavement.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 07-02-2014, 04:28 PM   #13
WhiteOut
WhiteOut's Avatar
This isn't a driveshaft issue or an issue with having only 2wd.
WhiteOut is offline   Reply With Quote
Unread 07-02-2014, 06:52 PM   #14
PolkaPower
True, learn to drive.
Unread 07-02-2014, 07:27 PM   #15
Technohead
Old School
Technohead's Avatar
Exactly.
You don't need full time 4wd to drive in the rain. The vast majority of cars on the road at 2wd.
Technohead is offline   Reply With Quote
