Driving with bent tie rod? - JeepForum.com
post #1 of 10 Old 08-06-2009, 09:03 PM Thread Starter
FrankTheDank
ok, retarded question, but how bad is driving with a bent tie rod, i'll get pics up soon, but as stated i bent my tie rod and need to drive to Denver (about 100 miles) how bad would it be to do this round trip, i figure it will contribute to uneven tire ware atleast
::4.0::42RE::242::Carolina Driveline::Spartan Locked D30::Aussie locked 44A::4.56!!!::4'' IRO LA::33/12'' Retreads::4"BS wheels::IRO T case skid::2 12'' Kenwood Subs 1000 Watt Kenwood Amp::Iceland Winch Bumper::Smittybilt XRC8::
STOCK 97 ZJ LAREDO-Daily Driver
I don't need to lie...that way I never have to remember what I said
FrankTheDank is offline
post #2 of 10 Old 08-06-2009, 09:16 PM
gatorayde
It depends on how bad it is. If it's a slight bend, I'd say check it after ~25 miles or so and make sure the tires are still OK. If it's got a kink in it, definately swap it out. Last thing you want is for the tire to wear through and cause a blowout, I've seen it too many times at work...
gatorayde is offline
post #3 of 10 Old 08-06-2009, 10:38 PM
StrokedWJ
StrokedWJ's Avatar
x2...Mines been slightly bent for ~ 3 years. Theres enough adjustment during an alignment to get everything in spec.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #4 of 10 Old 08-07-2009, 01:03 PM Thread Starter
FrankTheDank
few pics, i'd call it more of a slight bend rather than a kink, compared to other pics i was able to find
Maybe try the bottle jack trick?
post #5 of 10 Old 08-07-2009, 01:51 PM
Bama_WJ
Bama_WJ's Avatar
Mine was probably slightly less bent than that and I had no idea. I probably drove close to 1000 miles with it like that. Tires seemed to be fine. I ended up upgrading to Kevins HD tie rod.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #6 of 10 Old 08-07-2009, 02:08 PM Thread Starter
FrankTheDank
ya, i plan on going with kevins, just waiting for pay day
post #7 of 10 Old 08-07-2009, 03:40 PM
Bort62
Take it off and bend it back
I bent mine on the trail a few weeks ago, Had about 1.5" toe in....
so I took it off over lunch and stuck the end in my hitch and sat on it to bend it back.
put it back in and re-aligned... maybe 30 minutes.
___________
'98 Grand
'60 Ranchero
Bort62 is offline
post #8 of 10 Old 08-07-2009, 04:36 PM
comptiger5000
I've seen smaller amounts of bend destroy stock tie rod ends over the course of a few years. It can be bad enough to have 20* of play in the wheel at 70mph.
comptiger5000 is offline
post #9 of 10 Old 08-07-2009, 05:49 PM Thread Starter
FrankTheDank
its only been like this for maybe 2 weeks, and the jeep has only been around town and offroad, i plan on replacing it some time shortly after the trip, i'm going to try to straiten it for now
post #10 of 10 Old 08-07-2009, 08:19 PM
nierace
nierace's Avatar
2003 WJ
You'll be fine, mine looked like a pretzel when I did a 400 mile trip with no probs. The tires arent going to die after a couple hundred miles with poor toe-in.
I had the JKS one but it was such a pain to adjust I put a stock one back on. I bought a new one from autozone for $35 I think? The old one serves as a awesome breaker bar !
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
Driving On Icy Roads Type Of Driving kopite77 ZJ Grand Cherokee Forum 22 01-06-2010 04:03 PM
Tie-rod bent alexsious ZJ Grand Cherokee Forum 19 01-10-2009 03:14 PM
Bent Oil Pan - 4.0L UofOJeeper ZJ Grand Cherokee Forum 11 02-19-2008 08:48 PM
Bent Axle? Slamm36 ZJ Grand Cherokee Forum 43 06-08-2006 09:03 PM
Bent Tie Rod?? greasefingers ZJ Grand Cherokee Forum 16 03-31-2005 10:00 PM
