Driving 100kph = 3,000rpms - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Driving 100kph = 3,000rpms
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 09-16-2006, 03:15 PM   #1
schwa
1994 ZJ
Normally driving at 100kph on the highway I'd get about 2,100 rpms but just recently it would reach up to 3,000rpm's. On the odd time it would level out back down to 2,100 give or take.
Could this be a faulty sensor? Or just a leak in the exhaust manifold/pipes?
I have a 94 Grand Cherokee, I'll be replacing the cat convertor, muffler and oxygen sensor soon.
Anyone have any ideas of why I'm getting such a high rpm?
schwa is offline   Reply With Quote
Unread 09-16-2006, 04:08 PM   #2
KingPrat
Sounds kinda like your TPS
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust
Nokian Vatiiva tires: 235/65-17
Previous:1997 ZJ TSi 4.0. Some stuff added
Western New England College '08
Golden Bear Lacrosse #13
Week 11 USILA Rank: #15
2008: 16-5
NCAA Elite 8
TCCC Champions
Please read and share!!
KingPrat is offline   Reply With Quote
Unread 09-16-2006, 04:23 PM   #3
rm2001wj
You are using the tach to read the engine speed increase, but do you hear the engine speed increase as well? If you do, then I would suspect a problem with the transmission.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
rm2001wj is offline   Reply With Quote
Unread 09-16-2006, 04:37 PM   #4
schwa
1994 ZJ
Figures, i guess my 1st gear is slipping.
Anyone know the costs and time it takes to repair such?
In Vancouver Canada?
Unread 09-16-2006, 10:44 PM   #5
phasewolf
In Michigan it cost me $1350 to have the trans rebuilt.
phasewolf is offline   Reply With Quote
Unread 09-16-2006, 10:55 PM   #6
JeepHunter89
Do you have your overdrive on? Because mine goes from about 2000 to 3000 RPM's when I turn it on.
JeepHunter89 is offline   Reply With Quote
Unread 09-17-2006, 03:52 AM   #7
schwa
1994 ZJ
Overdrive is off, sometimes it will engage by itself and won't turn off when i push the button.
Unread 09-17-2006, 09:48 AM   #8
eagleknight
I think you have this backwards. With overdrive off you should be at around 3000rpms. You should have overdrive on for normal driving and that will have you around 2100rpms. Really the only time to turn it off is if your hauling a trailer. Even on the trail there is no reason to turn it off because you probaly won't be up in the higher gears anyway.
Now if it is on (which is default) and you hearing the engine going to up around 3000rpms. Then your transmission might be slipping or torque converter. I think I got that explained right.
97 ZJ 4.0
Current mods:
K&N Intake, Thorley header, Magna flow cat, Flowmaster muffler.
eagleknight is offline   Reply With Quote
Unread 09-17-2006, 11:55 AM   #9
phasewolf
If the light is off then the overdrive is on.
Unread 09-17-2006, 05:15 PM   #10
JeepHunter89
Yup, sorry. I just had a brainfart when posting.
Unread 09-17-2006, 10:48 PM   #11
FlashLCD33
Could it be a faulty overdrive switch kicking it on/off?
'93 Grand Cherokee Larado 4.0l - 4wd - Wrecked.
FlashLCD33 is offline   Reply With Quote
