Drivetain vibration and noise. 95 5.2 ZJ - JeepForum.com
post #1 of 5 Old 09-24-2017, 12:42 AM Thread Starter
Whiskeyirish
I recently bought a 95 ZJ 5.2(automatic) from a friend. I've noticed before when riding with him that every now and then there would be a vibration for just one or two seconds. (Almost identical to running over the rumble strips on the side of a highway, just not quite as loud or as bumpy and only lasted a second or two.) I drive it everyday now. Sometimes it does that and sometimes it doesnt. I feel like it's during shifts when it happens but not 100% sure.
If I step on the gas as soon as it happens it goes away immediately.
Other than this vibration. It shifts great and holds tranny fluid perfectly. Any ideas on what it could be?
Also, the All time 4x4 makes the tight inner city driving a real pain in the arse.
Would there be any serious reprocussion to removing either driveshaft for the time being. I'll be getting a new daily driver around the new year and I'd probably replace it then.
Whiskeyirish is offline
post #2 of 5 Old 09-24-2017, 02:09 AM
kg6mov
Hears the voices
kg6mov's Avatar
95 cooks the vc if you pull the front shaft. Can't pull the rear one either.
Get a new vc or swap the case, 231 is best clearance and simplest, 242 is same size and can have it's quirks.
Could be harmonic balancer, do you feel it in any part in particular (steering, pedals)?
kg6mov is offline
post #3 of 5 Old 09-24-2017, 05:16 AM
PolkaPower
If the viscous coupler is already bad then pulling the front shaft would certainly finish it off but I guess it doesn't matter at that point.
It's less stress on the tires and front end.
It will roll in park with the front shaft removed though.
You'd better not park on uneven ground and make sure your emergency brake works well.
PolkaPower is online now
post #4 of 5 Old 09-24-2017, 09:02 PM
papitt
.. Also I'll only throw this out there because you only have 1 post. But on our ZJ's running different size tires will cause you jeep to have a jump or quirk in it turning.
.. I remember the techs at the Jeep & Chrysler dealership I worked at wouldn't even tell people it they blew a tire. ThEY TOLD THE CUSTOMER that they had to BUY A COMPLETE NEW SET OF TIRES.
... So at least check your tires & make sure all 4 match & have the same amount of thread.
papitt is offline
post #5 of 5 Old 09-29-2017, 01:18 AM Thread Starter
Whiskeyirish
Thanks for all of the info guys. I've noticed here lately since the weather has gotten colder is hasn't done it at all.
I don't know if it has anything to do with me making sure overdrive is off Everytime I drive it but it's definitely not happened at all lately
