Driveshaft vibrations - angle or VC? - JeepForum.com
post #1 of 26 Old 06-03-2013, 02:10 PM Thread Starter
ZJMatt
Jeep in question is the bottom one in my sig. Has an NP249 t-case. I know the viscous coupler is bad, I'll be replacing it once I get the money for a 242.
The previous owner installed a 4.5" lift but admitted to me that it was his first time lifting a vehicle. The only thing I've noticed that isn't ideal, is that he has front upper fixed arms. The front lowers are adjustable, as well as all 4 in the rear.
The jeep had never been off-road before I bought it. When I bought it, it didn't have the front driveshaft installed because he said it was giving him horrible vibrations since doing the lift, so he pulled it out. He also installed a t-case drop hoping it would fix the problem but he said it didn't. It was the CV style, which doesn't have the telescoping capabilities of the U-Joint style. So I swapped the pinion yoke and driveshaft out of my old jeep. I also took the t-case drop out, because well, it's a t-case drop.
I still have sporadic driveshaft vibrations. Sometimes it'll go down the road perfectly smooth. Other times it's just a light hum. Other times it'll shake everything. It's not even dependent on the speed - just whenever it feels like vibrating it will.
I measured the driveshaft angle with a digital inclinometer. It measures 11.6. I know the drive shaft and u-joints are good, since this shaft came out of my old jeep, which last time I drove it was 30 miles in front-wheel-drive, and it didn't vibrate or make any noise.
Also as I said I know the viscous coupler is beyond shot. I never did the figure-8 test because I could feel it just pulling out of my driveway.
So, could the viscous also cause a vibration? What should my driveshaft angle ideally be at? My guess is the p/o put in adjustable arms, but didn't know how to adjust them. To decrease the angle, I would want to adjust them in, correct?
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #2 of 26 Old 06-03-2013, 02:33 PM
WhiteOut
WhiteOut's Avatar
The pinion should be pointing at the output on the transfer case. Also possible you have a joint on its way out.
Pull the shaft again (your case is already wrecked) and see if the vibes continue.
WhiteOut is offline
post #3 of 26 Old 06-03-2013, 02:42 PM Thread Starter
ZJMatt
As I said, the u-joints are OK. They were recently replaced when the shaft was in my other jeep, and I had no issues with that one.
What do you mean by "pointing at?" The driveshaft should have zero angle to it?
I don't want to pull the shaft because I frequently need 4 wheel drive.
ZJMatt is offline
post #4 of 26 Old 06-03-2013, 02:55 PM
kg6mov
Hears the voices
kg6mov's Avatar
Pinion bearing? Maybe missed something when you did the swap?
VC shouldn't cause vibrations, shot vc just means you are locked 4wd, which if anything would make any vibrations consistent with speed.
Pinion angle should be set so the driveshaft is basically straight coming out of the diff, and only bends at the t-case.
kg6mov is offline
post #5 of 26 Old 06-03-2013, 04:12 PM
WhiteOut
WhiteOut's Avatar
Pull the shaft, drive around for 20 minutes and see if it happens.
Easiest way to eliminate a part.
WhiteOut is offline
post #6 of 26 Old 06-03-2013, 04:14 PM Thread Starter
ZJMatt
As mentioned, it does not vibrate with the front shaft removed. This front shaft also did not cause any issues in my old jeep (same lift height, longer fixed lowers & stock uppers). Therefore I don't believe it's the shaft itself or a joint that's bad, but instead my angles.
Here is a pic of the pinion yoke & shaft
ZJMatt is offline
post #7 of 26 Old 06-03-2013, 04:19 PM Thread Starter
ZJMatt
Just took a few more measurements, pinion angle as relative to driveshaft angle.
Pinion angle (inclinonmeter on the top of the u-joint yoke) - 1.0 tilted up
Driveshaft angle - 11.6 same direction.
So it seems the driveshaft is 10.6 off from the pinion, and they should be the same, correct?
Can I make this adjustment with fixed uppers and adjustable lowers?
ZJMatt is offline
post #8 of 26 Old 06-03-2013, 04:29 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
The cause of your vibes from looking at the pic. Pinion seal is leaking too, ergo I would check for lateral slop where the driveshaft enters the diff. You should have about 1 degree pinion angle.
HighLonesome is offline
post #9 of 26 Old 06-03-2013, 04:38 PM
speedbucket
Unless I'm misreading that then I completely disagree. Pinion angle should be as close to the driveshaft angle as possible. The really crappy angle he has in the pics probably caused the pinion seal leak because the joint is out of alignment on the elliptical rotation with the CV joint at the case.
This is what it should look like
Iirc my pinion is around 5-7 degrees
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #10 of 26 Old 06-03-2013, 04:39 PM
speedbucket
Lengthen the uppers or shorten the lowers. To fix......
post #11 of 26 Old 06-03-2013, 04:42 PM
WhiteOut
WhiteOut's Avatar
Diff should be pointing at the t-case output.
WhiteOut is offline
post #12 of 26 Old 06-03-2013, 04:50 PM
HighLonesome
See how the driveshaft is a perfectly straight line coming from the diff? That is where the 1 degree should be.
post #13 of 26 Old 06-03-2013, 05:03 PM
speedbucket
Angles are always given from 0(flat) or vertical from 90. I understand what you meant now
post #14 of 26 Old 06-03-2013, 05:25 PM
HighLonesome
And you I.
post #15 of 26 Old 06-03-2013, 06:02 PM
Crasher
FWIW, The LCAs are for axle placement in the wheel well and the UCAs are for pinion adjustment. To do it correctly, you need adjustable uppers to push the top forward until the pinion is the same angle as the DS.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
