Driveshaft slip yoke lubrication - JeepForum.com
post #1 of 3 Old 06-03-2012, 07:13 AM Thread Starter
4Slow9erHybrid
What is the best lubricant for the rear DS slip yoke? Would antiseize (copper based) be better than chassis grease? One issue with the rear DS slip yoke that it has a play even though the slip yoke is new and no signs of wear on the TC output shaft. What lubricant would be best to minimize this play? Thicker grease?
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #2 of 3 Old 06-03-2012, 02:46 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
play is normal.
you'll probably want to use a LIGHT coating of an ep grease.
ratmonkey is offline
post #3 of 3 Old 06-03-2012, 04:03 PM
LouC
2007 WK
I use OMC/Bombardier Triple Guard Grease, it is a very heavy duty marine grease that is for driveshaft splines on inboard-outboard marine engines and it works great on driveshaft splines on Jeeps too. You can get it from any Evinrude dealer. Better than car based greases, holds up to salt water and water in general very well.
LouC is offline
slip yoke question? nothing to do with SYE!! speedbucket ZJ Grand Cherokee Forum 0 03-02-2011 12:17 PM
slip yoke elimator jjjacobs81 ZJ Grand Cherokee Forum 11 01-06-2011 06:10 PM
Slip yoke and no slip yoke? Dillonzj ZJ Grand Cherokee Forum 3 07-24-2008 09:59 AM
How to replace the grease seal of the front driveshaft / slip yoke knl ZJ Grand Cherokee Forum 4 04-22-2008 06:58 PM
ZJ slip yoke front DS Steve98 ZJ Grand Cherokee Forum 15 02-07-2007 07:32 PM
