Driveshaft shortening after 231 install??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Driveshaft shortening after 231 install???
The Original 3/8" Ruffstuff Diff Cover!3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-06-2015, 04:57 PM   #1
evan1395
So i got my new (used) 44re installed and backed by my 231 in place of my 249. But my mechanic had to send off my rear driveline to have it shortened a tad.
Why is this? After reading and researching all these months, I dont recall reading about this being a factor in the swap?
Any ideas?
J.E.E.P (Just Empty Every Pocket)
evan1395 is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 07:45 PM   #2
jm8881
My driveshaft barely fit after my 231 swap but I'm lifted 4.5" and have moved my axle back an inch or so.
jm8881 is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 07:49 PM   #3
kg6mov
Hears the voices
kg6mov's Avatar
If the 231 was external slip yoke then the shaft will need to be shortened slightly compared to the internal slip yoke of the 249.
Originally Posted by kg6mov View Post
ESY:
ISY:
If you install an ESY case in place of an ISY case you may need to shorten the rear shaft by about an inch.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 08-06-2015, 10:20 PM   #4
evan1395
It was surely an ISY.
Guess that makes sense now. This wont throw off my rear pinion angle, will it?
Unread 08-07-2015, 12:59 AM   #5
kg6mov
Hears the voices
kg6mov's Avatar
Nah, V8 shafts are so long that it doesn't matter.
Unread 08-07-2015, 02:36 AM   #6
evan1395
Ok cool.
I have the IRO rear upper adjustable arms anyway. Just in case I suppose
