Quantcast driveshaft removal Q - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > driveshaft removal Q
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 12-10-2007, 10:36 PM   #1
scubatch2
I would like to disconnect the frt driveshaft at the axle and tie it up(make a secure holder) ,and drive it around.is this safe.I have a 231w/vibs.its a pain to do both ends(I know only about 5-10min)It would just make it alot easier to only do the one end.
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
jeep pics
scubatch2 is offline   Reply With Quote
Old 12-10-2007, 10:42 PM   #2
driabyor
1994 ZJ
sounds like a bad idea ,,, as you would have to disconnect it at the axle... if the homemade holder ever broke, you would have an instant parking brake...
It would be safer to just take it out. IMO
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline   Reply With Quote
Old 12-10-2007, 10:45 PM   #3
QuadraTokn
1930 WJ
Sounds like a bad idea. its probably as dangerous as driving around with an office chair under your hub when you cant find your spare tire.
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is online now   Reply With Quote
Old 12-10-2007, 10:48 PM   #4
scubatch2
Thats the same thing i was thinking of,but in theory it would be fine,the transfercase end should not turn if its in 2wd.
- jeff-
jeep pics
Old 12-10-2007, 10:54 PM   #5
nierace
2003 WJ
Tis a bad idea =)
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote
Old 12-10-2007, 11:11 PM   #6
scubatch2
Ok ,you talked me out of it.I'd probably would have been up for a Darwin award if I did it
- jeff-
jeep pics
Old 12-10-2007, 11:13 PM   #7
Darthteddy
1955 M-38
Just take it out. Its only a few extra clips or whatever right?
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline   Reply With Quote
Old 12-10-2007, 11:13 PM   #8
Kruzin
It's only a few more bolts to fully remove it. Don't take the chance. That thing breaks loose, you do hundreds of $$ of damage, and risk throwing debris on the road, damaging other vehicles. Not worth the risk.
DD: 98 ZJ Laredo 5.2, all stock
Wheeler/Beater: 93 ZJ Laredo
4.0, AW4, 231 conversion from 249
3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard
Colorado Jeep Club Member 242 (4.0L)
Kruzin is offline   Reply With Quote
Old 12-11-2007, 12:30 AM   #9
ajmorell
ajmorell's Avatar
That's a horrible idea. The drive shaft is going to rotate regardless of whether or not you have it connected to the transfer case. It is a total of 8 bolts, it will only take you 10 min to remove all 8 of them.
Andy
'98 Jeep ZJ "Pearl"
ajmorell is offline   Reply With Quote
Old 12-11-2007, 01:00 AM   #10
scubatch2
[quote=ajmorell]That's a horrible idea. The drive shaft is going to rotate regardless of whether or not you have it connected to the transfer case.[QUOTE]
I'm not doing it,like I said earlier,but the shaft should not rotate if it is connected only at the tc.when in 2wd it only rotates because its connected to the front axle.
- jeff-
jeep pics
Old 12-11-2007, 11:13 AM   #11
ajmorell
ajmorell's Avatar
never mind, i read it wrong.....
Andy
'98 Jeep ZJ "Pearl"
Glock Forum
