driveshaft/differential problem? - JeepForum.com
post #1 of 8 Old 08-11-2011, 10:47 PM Thread Starter
mntsitalons
Got a 95 grand cherokee and the transfer case blew up a while back. I was having trouble finding the cv style drive shaft so today i finally got the yoke on the front end switched out and installed the ujoint style ds. Everything fit well, except for when i started driving it, the front end seems tight. There's quite a bit of sound coming from the what sounds like the front differential. It didn't make any sounds until I installed the driveshaft.
Any thoughts on what this would be? Pinion/Carrier bearings?
Thanks.
mntsitalons is offline
post #2 of 8 Old 08-12-2011, 05:54 AM
Midnightluckey
What transfer case do you have? Have you been driving it without the front driveshaft?
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #3 of 8 Old 08-12-2011, 06:00 AM
speedbucket
lemme guess
you just cranked the pinion nut off, slapped the new yoke on, and bubba tightened it back down?
or you burned up the VC on your "new" transfer case by driving it with no front driveshaft
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #4 of 8 Old 08-12-2011, 06:42 AM
Midnightluckey
Originally Posted by speedbucket
lemme guess
The correct way is to impact it on.
post #5 of 8 Old 08-12-2011, 07:49 AM Thread Starter
mntsitalons
Its the 249 tc. I wasnt sure what took the transfer case out to begin with,so I just put the ds on temporary to see if the front end was making noise. It was making noise before the transfer case went out. I drove it for a half mile after installing the drive shaft, didnt figure it would cause a problem just wanted to hear what was going on. Maybe I screwed more up by doing that And yes I've been driving it without the driveshaft for a while now.
post #6 of 8 Old 08-12-2011, 08:15 AM
Midnightluckey
No, if you screwed anything up, it's the vc in the new case by driving it without that front shaft.. And it sounds like your problem actually originates from the front diff.
post #7 of 8 Old 08-12-2011, 09:45 AM
speedbucket
my guess is the pinion preload is too much (cant un-crush a crush sleeve) , and you have a toasted Viscous Coupler in the transfer case
welcome to the forum and research is important!
post #8 of 8 Old 08-13-2011, 12:11 PM Thread Starter
mntsitalons
Alright well regarding the viscous coupler are they the same on all 249's? I found out that there are 2 different input shaft lengths in the 249. The original one that went out was an inch longer than the 249 i bought to replace it, so I had to find another case with the longer shaft. The shorter shaft wouldnt reach the seals ;( So would the coupler be the same on the other case I still have? Even after I swtich that out i think I need a new pinion. Also I'm doing this because I want to sell it. It has 140k miles on it and the motor and tranny is solid. I'm not sure if I should put the money into it to fix it or just sell it as is....
Screeching from front differential @ driveshaft egleas522 ZJ Grand Cherokee Forum 33 08-09-2009 09:23 PM
rear differential driveshaft seal tfgnt16 ZJ Grand Cherokee Forum 0 03-01-2009 02:44 PM
1998 Grand Cherokee Front Differential and driveshaft? jjeeeeppss ZJ Grand Cherokee Forum 5 08-09-2008 07:56 PM
97 TSi, differential problem Picolini ZJ Grand Cherokee Forum 19 06-05-2008 10:28 PM
Differential/Axle/Driveshaft Issue... Ds4x4 ZJ Grand Cherokee Forum 9 01-02-2008 10:54 AM
