Driveshaft bolts - JeepForum.com
post #1 of 13 Old 11-17-2010, 10:14 PM Thread Starter
johnnygoose
Driveshaft bolts
Where can I find the front driveshaft bolts, the ones on the differential side not the transfer case side. There's six of them and the dealer wants $7 each. Don't think a regular bolt will work.
johnnygoose is offline
post #2 of 13 Old 11-17-2010, 10:18 PM
94chb
i have some, i just swapped the cv style drive shaft to the u joint style
94chb is offline
post #3 of 13 Old 11-17-2010, 11:13 PM
ZJ5point2GCL
I got mine at the bolt supply house here,i forget what its called though. I believe its just an 8mm, i dont remember it being anything special. and they weren't expensive at all, i ended up buying the guy a coffee so he didn't have to do any paper works for such a little order.
do you have at least one good one for comparison?
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #4 of 13 Old 11-18-2010, 12:19 AM
WhiteOut
WhiteOut's Avatar
These are the ones that hold the little straps right?
Im positive I have a bunch laying around from 2 or 3 shafts. If I have them mail would probably take 4 days or so.
WhiteOut is offline
post #5 of 13 Old 11-18-2010, 12:28 AM
94chb
yea, do you have any shafts? i broke mine at the cv
94chb is offline
post #6 of 13 Old 11-18-2010, 07:59 AM Thread Starter
johnnygoose
These bolts are threaded the entire length, the bolts at the hardware store are not and it looked like the part that was not threaded was a larger diameter. Maybe that small difference won't matter. I would rather have the originals. I'll post a picture tonight and anyone that has three for sale that match can PM me.
post #7 of 13 Old 11-18-2010, 08:55 AM
RyanZJ
RyanZJ's Avatar
Any auto parts store should carry them. I bought a set of 4, complete with u-joint straps, from Pep Boys for something like $3.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #8 of 13 Old 11-18-2010, 09:27 AM
bboylobo
2005 WK
i got mine at an auto parts store. they are 1.25 x 8m
bboylobo is offline
post #9 of 13 Old 11-18-2010, 10:37 PM Thread Starter
johnnygoose
Here's a picture of one. I work mon - fri can't get to a supply house. Any auto parts stores carry these.
post #10 of 13 Old 11-18-2010, 10:53 PM
ZJ5point2GCL
napa would carry them for sure, probably any other parts stores too.
they might come in a kit with new straps, but wouldn't be very expensive anyways
post #11 of 13 Old 11-18-2010, 11:43 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Sounds like you have a compantion flange, not a yoke. Ergo, the strap screws aren't likely to work for you (for most light-duty automotive apps, the strap screws are 1/4"-28. Companion flange screws can be 5/16", 3/8", M8, or M10.)
As for the shoulder - standard practise (ISO or SAE) is to thread the screw for up to three times its nominal diameter - a 1/4" screw, 1" long, will be threaded for 3/4" of its length and the 1/4" directly under the head will be full nominal diameter with no threads (called "shoulder" or "grip.")
Most hardware stores and such will stick to this standard. You can get fully-threaded screws, but they generally have to be had from a fastener house - they can be had rather easily from Fastenal. Check their site (Home | Fastenal) for a branch local to you - they're a handy source, and their only flaw is that they tend to keep banker's hours.
A CV-style pinion flange is probably late enough that it's an ISO screw, and light enough that it's probably an M8-1.25. Do you recall what wrench you used to remove it, and whether the head of the screw had hash marks (SAE) or a number (ISO?)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #12 of 13 Old 11-19-2010, 04:38 AM
newfieZJ
U-pull , cheap if not free . Mine would not charge me for a few bolts . If you need those washers , get em there too .
newfieZJ is offline
post #13 of 13 Old 11-19-2010, 08:21 AM Thread Starter
johnnygoose
It is a CV-Style flange. The bolts are metric and I think it was an 8mm socket that I used. Tried Advance Auto their hardware section was pathetic, I'll try some of the others Saturday.
broke sway bar link bolts at axel, need new bolts 2tone93zj ZJ Grand Cherokee Forum 2 10-28-2009 04:57 PM
Bolts for the driveshaft shdybrady19 ZJ Grand Cherokee Forum 5 12-21-2008 06:41 PM
driveshaft u-bolts universal? a70eliminator ZJ Grand Cherokee Forum 2 06-18-2007 06:56 PM
cam bolts sandman ZJ Grand Cherokee Forum 5 06-07-2007 10:12 AM
How much torque for Driveshaft bolts? defffrek ZJ Grand Cherokee Forum 1 11-24-2004 09:04 AM
