driveshaft: 242, 249, or 231? - JeepForum.com
post #1 of 7 Old 12-03-2004, 09:12 PM Thread Starter
K-Pax
K-Pax's Avatar
i checked the build sheet for my GC and only found:
4-speed auto
42RE tranny
lock-up torque converter (whatever this does)
3.73 axle ratio
dana 35c/194mm rear axle
i am looking to replacing the front axles, but the build sheet doesn't say what type the front ones are. would anyone here know by the info i have given (all the info i have atm). i may just need some translating done hehe.
Graphic Design student at NWACC (Northwest Arkansas Community College).
Kevin's rig:
94 Grand Cherokee Laredo
I-6 4.0L, Quadra-Trac on demand
2" budget lift
pro-comp steelies
kevin's radiator support bar
JKS quick discos
K-Pax is offline
post #2 of 7 Old 12-03-2004, 11:27 PM
Meerkat
You have the NVG249 transfer case
You have the Dana 30 front differential
Front gear will have a 3.73 axle ratio to match the rear
What the lock-up torque converter does is to "lock" into a 1:1 reduction ratio when cruising at highway speed. This is to improve fuel mileage. If your throttle position or engine speed changes at all, it will automatically disengage. You can't see or feel it engage or disengage.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 7 Old 12-04-2004, 07:30 AM Thread Starter
K-Pax
K-Pax's Avatar
ah...i can see the light once more! thank you warren, i knew i could count on you! ever thought about opening up a school?
Kevin's rig:
2" budget lift
pro-comp steelies
JKS quick discos
K-Pax is offline
post #4 of 7 Old 12-04-2004, 08:39 AM
Meerkat
On this forum I rather think of myself as more the student than the teacher. Seems I learn something new every day on here.
Warren
Meerkat is offline
post #5 of 7 Old 12-04-2004, 08:54 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
WVD is in training for his black belt in JeepDO.
Hunter
Jeep Jedi Master
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 7 Old 12-04-2004, 11:26 AM
Phil Gerard
Former Mod
Phil Gerard's Avatar
Hunter
Jeep Jedi Master
While the rest of us try to wash off all the Jeep DO DO!!
My thanks to you all!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #7 of 7 Old 12-04-2004, 12:42 PM Thread Starter
K-Pax
K-Pax's Avatar
sorry, didn't mean to single out warren, but there are many others here i look up to as well.
Kevin's rig:
2" budget lift
pro-comp steelies
JKS quick discos
K-Pax is offline
WJ Driveshaft and TSB 03-05-00 semperteneo ZJ Grand Cherokee Forum 5 12-10-2009 07:08 AM
driveshaft biff342 ZJ Grand Cherokee Forum 7 12-10-2008 01:56 AM
zj driveshaft shdybrady19 ZJ Grand Cherokee Forum 9 11-20-2008 03:01 PM
Driveshaft Q jeremy18 ZJ Grand Cherokee Forum 14 11-01-2008 05:15 PM
Help with 94 ZJ Driveshaft OffroadZJ ZJ Grand Cherokee Forum 9 12-10-2004 12:08 AM
