Driverside Whining Noise - JeepForum.com
post #1 of 10 Old 11-02-2005, 08:16 AM Thread Starter
Liamoc
When driving to work the other day with the radio off I noticed a whinning coming from the driver side front tire ( at least I think its the front tire). Sounds like the tire is rubbing on something. Stopped checked the tires, no rubbing, tread OK, no leaking,, all seams fine. Start back up whinning starts again when I go over 10-15mph. I don't think its a differential problem because noise continues whether i'm on or off the gas. Anyone have any suggestions as to what this could be?
2002 Jeep Grand Cherokee
36,000 miles
6 cyl
Select-Track
Liamoc is offline
post #2 of 10 Old 11-02-2005, 08:23 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Do you have quadra-drive? How long have you had it?
QD makes a considerable "whine" that is normal. Perhaps you just didn't notice it before
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #3 of 10 Old 11-02-2005, 08:33 AM Thread Starter
Liamoc
I've had the car for about 8 months( purchesed from in-laws) , its 6 cyl , with select-track. (Not sure about quadra-drive) Definately didn't have this noise before. Its pretty loud whith the window open.
Liamoc is offline
post #4 of 10 Old 11-02-2005, 08:40 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Hmm, are your lug nuts tight? I would look over the steering components in the front and verify everything is tight.
You didn't hit a bump or go over a curb prior to this noise starting, did you? It almost sounds like maybe the alignment is way off. Is it driving straight without any pulling to one side?
I'm still thinking. Need coffee.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #5 of 10 Old 11-02-2005, 08:52 AM Thread Starter
Liamoc
I haven't hit any curbs or large bumps. Just city driving to and from work. Car drives straight with no pulling either way. I did change the driver side rear tire 2 months ago, but this noise just started the other day.
Liamoc is offline
post #6 of 10 Old 11-02-2005, 08:55 AM
jeepholic
jeepholic's Avatar
Have you tried to jack that side up and spin the wheel, also a stethescope or a screwdriver with your ear pressed against it will help narrow down where it comes from.
Things that go whine;
Wheel bearings
Brakes
No oil in the front diff
pulleys and tensioners
water pumps
Check your belt
Rotate the tires to see if that helps
It's just at 36,000 miles you should not have those problems.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #7 of 10 Old 11-02-2005, 08:56 AM
Woody
Woody's Avatar
1985
Are all of your tires the same tread pattern? Do they have the same amount of tread left? Are you in 4 full time or 2wd?
Still waking up.
Woody
Woody is offline
post #8 of 10 Old 11-02-2005, 09:07 AM Thread Starter
Liamoc
I'll have to jack the car up tonight for closer inspection, But all looked ok ( brakes, tires, etc) Tire tread patterns are all the same with the passagner side rear tire having the least amount of ware. I aired up all tires and was still getting the noise. The whine is hard to tell if its coming from front or back, but i can't believe a new tire could make that much noise.
Liamoc is offline
post #9 of 10 Old 11-02-2005, 09:22 AM
Phil Gerard
Former Mod
Phil Gerard's Avatar
With a unibody it's difficult to pin down noises. Re you feeling any vibration in the wheel or on the gas pedal/ floor area?
I would start with the diffs because hopefully you'll eliminate an expensive problem first. Check your front and rear differential fluid. Unfortunately if it is low on fluid and already whining that not a good thing. Check them and if OK check your transfer case fluid.
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #10 of 10 Old 11-02-2005, 02:27 PM
Jeep-Tech1
It's probably just the hub bearing. Do alot of these on the grands... Hope this helps. Go to napa and get it though. Cause were to high on the part. thank chrysler for that one...
Jeep-Tech1 is offline
Humming noise from driverside undercarriage 97DCZJ ZJ Grand Cherokee Forum 8 09-08-2009 09:26 PM
Another day, another noise - whining noise while accelerating and slowing swataz ZJ Grand Cherokee Forum 8 12-11-2008 09:05 PM
whining noise gebster WK Grand Cherokee & XK Commander Forum 15 05-16-2008 06:39 AM
Whining noise when I let off the gas Myrtle Beach ZJ Grand Cherokee Forum 15 11-23-2004 09:18 AM
cherping noise/whining noise coming from passanger side LoweBudget ZJ Grand Cherokee Forum 0 12-06-2002 11:10 AM
