Drivers Side window Fell???? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Drivers Side window Fell????
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 04-06-2008, 04:29 PM   #1
mortation
Wife came home and said the window just "fell" down slowely like she had rolled it down. So I pulled the door panel off and o Joy I only get this little tine hole to work in.
I can see anything wrong other than the window is all the way down the button engages the motor and it tries to do stuff but nothing happens. There is a metal cable that has slack and tightens when I push the window up.
If i let go it slides right back down. Any one??? Please? Thanks!
mortation is offline   Reply With Quote
Unread 04-06-2008, 05:32 PM   #2
tsconver
2003 WJ
do a search you have just encountered teh dreaded broken regulator. Not repairable need a new regulator, $120 at autozone $250 at dealer, get dealer if still under warranty. Not bad to replace yourself.
by the way add some vehicle info for better troubleshooting responses, I am assuming you have a 99 - 04 Grand Cherokee
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/h...umb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/h...mage0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Unread 04-06-2008, 05:58 PM   #3
GraKee99
Rapist Wit
GraKee99's Avatar
There are ones on ebay for cheap.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote
Unread 04-06-2008, 06:00 PM   #4
ARFuniN
Check out : http://jeepin.com/features/wj_window_regulator/
The regulator may look ok while it is in the door but if you run your hand up the vertical track inside the door you will find the end of the 'lifting cable' that was once tied to the regulator cener lifting assembly.
Check out Rockauto.com...there is also an online coupon for 5% off your purchase, just search for Rockauto coupons and follow the directions. I curreently have a passenger regulator on order for $96 to my door. I have the pleasure of owning two Chrysler products with disposable regulators/motors and Rockauto got me the last power window motor within six days by ground.
ARFuniN is offline   Reply With Quote
Unread 04-06-2008, 06:13 PM   #5
JakeDS
I had both front regs fail within two weeks of each other. Talk about timing.
Right you are, Ken.
[URL="http://www.jakeselectricalservices.com"]Jake's Electrical Services, Inc.[/URL]
JakeDS is offline   Reply With Quote
Unread 04-06-2008, 07:06 PM   #6
tozar
The motors, tracks, cabling, etc., are not what breaks. It is the POS plastic block that the up/down cables are attached to.
It sounds like your nylon plastic block broke and your up regulator cable is hanging loose. The cable is probably wrapped around the spool too. I had the same thing a few weeks ago. You'll need to open up the motor spool and straighten out the cable where it's bent and wrapped up. Nothing too major.
It is easy to fix, and if your are ok with changing out the window regulator, then I would suggest that you get these aluminum blocks to replace the plastic blocks for the window regulator cables:
http://pocketlogger.com/?pid=jpw
I bought four. One for each window. They're about $30 each. Say good bye to broken window regulator problems.
-- Roy
tozar is offline   Reply With Quote
Unread 04-07-2008, 01:21 PM   #7
mortation
Thanks guys. I was hoping it was quick and easy. I have not even owned this thing a month yet. ITs going back to the dealer to be fixed. Already been back to have the heater core done. I will order some of those aluminum blocks soon and swap them out of all 4 windows.
2002 Grand Cherokee Laredo
