drivers side PL wont lock w remote or switch - JeepForum.com
post #1 of 3 Old 04-07-2009, 10:27 PM Thread Starter
fsu421
Hello,
I have a 97 Jeep Grand Cherokee LTD. When I hit lock on the remote, all the doors lock except the drivers side, same thing if I hit the switch inside. Every once in a while the drivers door will lock, but then when I hit unlock on the remote it wont unlock and I have to reach over from the passenger side to unlock it. Any ideas what I need to do to fix this?
Thanks in advance for any help!
Steve
fsu421 is offline
post #2 of 3 Old 04-07-2009, 10:47 PM
Vestjam
Check the wires loom that runs in between the door and the fender (inside the rubber boot). Sometimes a wire(s) will break in there. Although, it usually happens to the driver side first...
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #3 of 3 Old 04-08-2009, 07:10 AM
darkfour
If it makes a loud(ish) noise when you operate the locks then the door actuator is on it's way out. It's a non-serviceable part and replacement is the way to go. I had to do both actuators on the passenger side recently and picked up a couple of them used from ebay for $30 each. The install is pretty simple only it's a bit fiddly getting the clips off the control rods.
darkfour is offline
dome lights stay on no power window/lock drivers side nightmareny ZJ Grand Cherokee Forum 3 11-26-2008 06:15 PM
Dashboard problem, remote won't open drivers door and now doesn't start inorval ZJ Grand Cherokee Forum 0 11-23-2008 03:54 PM
99 Grand Cherokee Ltd Heat on passenger side cold on Drivers side. WHATS WRONG?? nosguy ZJ Grand Cherokee Forum 9 12-30-2007 10:15 AM
Drivers side door lock switch won’t work? 02Lightning ZJ Grand Cherokee Forum 3 09-23-2006 09:02 AM
Nasty noise in rear drivers side electric lock 1999 GC duse_500_2001 ZJ Grand Cherokee Forum 1 10-27-2005 03:01 PM
