Drivers Door won't lock or unlock (w/fob) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Drivers Door won't lock or unlock (w/fob)
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 11-07-2007, 06:05 PM   #1
Jon08JK
Mine should have keyless entry, but doesn't. The last guy put in a remote starter, but the fobs do lock and unlock. The drivers door however does not. I took the panel off and looked and listened as I hit the lock and unlock. It appears that the actuator? stopped working? It's a black thing just inside the edge of the door by the latch part.
How do I get to this to replace it (if this is the problem)
2008 Sahara Auto 2 Door 20,450 miles JKUR Coils and shocks, Magnaflow, Superchip, Banks CAI, Winch, OBA and 4:88's
Jon08JK is offline   Reply With Quote
Unread 11-07-2007, 07:02 PM   #2
j.love
1994 ZJ
Will it lock and unlock with the buttons on the door panel? If it does, and the fob locks and unlocks the pass side door, then its in the wires from the fob to the selinoid. There is a rubber boot between the door and the body is usually where the wires get crimped.. I would look there and put a test meeter to work on those wires..
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline   Reply With Quote
Unread 11-07-2007, 07:08 PM   #3
Jon08JK
Sorry that I was not more clear.
It will not lock, by the remote or by the button on the door. I can only lock and unlock it by hand or by the key in the hole from outside
Unread 11-07-2007, 07:16 PM   #4
j.love
1994 ZJ
ok, the solenoid is shot.. Verry common. Three screws on the door jam should remove that part.. you can find one in a junkyard or try ebay.. I think your Haynes has a write up on it..
note* you should still check that your getting voltage at the solenoid!
David.
Joe Biden
Unread 11-07-2007, 07:24 PM   #5
Jon08JK
Is that the black thing that I am calling the 'actuator'? Thanks a lot!
Unread 11-07-2007, 07:33 PM   #6
j.love
1994 ZJ
Yes, its the latch and the "actuator" all in the same unit! They cant be separated.. I think each door is different. a left and right front and back!!!
David.
Joe Biden
Unread 11-07-2007, 07:35 PM   #7
Vestjam
Vestjam's Avatar
X2.... Did my 95ZJ (Drivers door) a few weeks ago. Very straight forward process.
2008 Jeep Wrangler X (Hard Top)
Incubus Off Road 511's with BFG 285/70-17
1998 Jeep Cherokee Sport
4.0L/AW4, Yakima Roof Rack
Vestjam is offline   Reply With Quote
Unread 11-26-2007, 08:57 PM   #8
michelle@ny
anyone have a part # for this?
michelle@ny is offline   Reply With Quote
Unread 11-26-2007, 10:28 PM   #9
j.love
1994 ZJ
http://cgi.ebay.com/ebaymotors/93-98...QQcmdZViewItem
Best I can do for ya.
David.
Joe Biden
