driver's door sensor?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > driver's door sensor??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 11-21-2007, 10:58 PM   #1
CMARJEEP
on both mine and my gf's grands the lights wont go on anymore once the door is opened. im thinking its a switch in the door somewhere. anyone had this problem or know how to fix it???
www.norcaljeepers.co
CMARJEEP is offline   Reply With Quote Quick reply to this message
Unread 11-21-2007, 11:15 PM   #2
Understr
my lights go on but, I constantly get a "door ajar" warning even when the door is shut...
Understr is offline   Reply With Quote Quick reply to this message
Unread 11-21-2007, 11:16 PM   #3
BucYouUp68
Check the Rear Light, I think I had clicked it off at one point, and all the interior lights stopped working. Once I clicked it again they all worked. LOL
Why is there a fish finder in your Jeep?
Not hard, if you have a socket wrench and the mental capacity of a ham sandwich.
BucYouUp68 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2007, 12:39 AM   #4
CMARJEEP
its not the rear light. i know if that is off then the lights wont come on but this is different because sometimes they wont go on at all when i open the door and sometimes i will open the door and 30 seconds later the lights will randomly come on. if i open any of the other doors the lights will come on right away so i have singled the drivers door as the problem. is there a switch or sensor that tells the lights to go on? how hard is it to change???
Unread 11-22-2007, 12:43 AM   #5
BucYouUp68
I will check Alldata for you, Stand By
Unread 11-22-2007, 12:52 AM   #6
BucYouUp68
Looks to be a Door Jamb Switch, and a Door Module, that could be the problem
Unread 11-22-2007, 01:09 AM   #7
CMARJEEP
thanks for looking that up for me. where is this drivers door control module??
Unread 11-22-2007, 01:15 AM   #8
BucYouUp68
Its behind the Door Panel
Unread 11-22-2007, 08:11 AM   #9
FlipFlop425
What about just cleaning out the latch in the door. Sometimes the grease covers the contact.
FlipFlop425 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2007, 08:38 AM   #10
_Kyle_
_Kyle_'s Avatar
The switch might be stuck in or to address another posters issue with the light always being on, get a small flat head screw driver and pry out the middle of the button (it can be adjusted) and then that should fix the issue. At least it did on mine. I think mine is worn out because I have to adjust it every few weeks because it slides back in.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
Kyle's TJ Build
_Kyle_ is offline   Reply With Quote Quick reply to this message
Unread 11-22-2007, 12:34 PM   #11
CMARJEEP
where is the switch though????
Unread 11-22-2007, 12:52 PM   #12
_Kyle_
_Kyle_'s Avatar
If you are looking from the outside in, its on the right side, below the metal piece for the latch. It's a round little black button shaped protrusion.
-Kyle
1996 Grand Cherokee
Kyle's TJ Build
Unread 11-22-2007, 01:26 PM   #13
CMARJEEP
must be different on WJs because i dont see it. i hope the switch isnt an internal thing.
Unread 02-09-2009, 10:28 AM   #14
Sfrid073
Bump. having same issue. looking for response. I dont think the WJ's have door jamb switches. Is it a bad door module?
2000 Jeep Wrangler, 6 cyl., auto, dual tops, bikini top
Sfrid073 is offline   Reply With Quote Quick reply to this message
Unread 02-09-2009, 10:32 AM   #15
QuadraTokn
1930 WJ
Dont mean to state the obvious but do you have the dome over-ride switch on?
LIKE US ON FACEBOOK: Valhalla Fabrication
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline   Reply With Quote Quick reply to this message
