drivers door power lock rear window hatch not opening - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > drivers door power lock rear window hatch not opening
All Bilstein shocks & struts - Lowest Prices Ever and RuffStuff Memorial Day Sale!Poison Spyder to donate 10% of Memorial Day W/E Sales to R
Unread 07-27-2007, 03:38 PM   #1
robbennett_4409
my drivers door will lock manually or with key but not with the fob same with the back window I can not push the button to open it I have to take the back panel off and release the actuator all other locks work no problem. are these on the same circuit I cannot find a fuse for them. Also my horn is not beeping it clicks at the relay swapped the relays and checked the fuses they are in working order.
thanks,
1996 Jeep Grand Cherokee Limited (2 of them)
robbennett_4409 is offline   Reply With Quote
Unread 07-27-2007, 04:23 PM   #2
FPKites
ZJjazzyJim
FPKites's Avatar
Word on the street has it that the control for the driver door is contained in the driver panel, all other doors' control is in the front passenger panel. The brain, that is.
You may have bad actuators. When you hit the fob, does the driver door make a teeny sound like it's not getting enough amps to do the job?
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Unread 07-27-2007, 04:37 PM   #3
robbennett_4409
when you put the ear up to the door you can hear a faint click nothing like the other doors so I started doing it and wiggling the harnass at the same time nothng still the faint click
Unread 07-27-2007, 04:56 PM   #4
FPKites
ZJjazzyJim
FPKites's Avatar
Mine does that too - probably a bad latch assembly. I have awful luck with those things. Every replacement I've gotten (junkyard, not dealer) were DOA I hit the fob, and it lets out a little fart and does nothing.
Jim Karlin
Unread 07-27-2007, 07:57 PM   #5
robbennett_4409
With the eception of the back door not happening this Jeep has all different problems. Took me ten minutes to get the rear door open and lubed up and adjusted real well remembered it from the red one.
Unread 08-16-2007, 08:35 AM   #6
robbennett_4409
The problem with the drivers door was it was unplugged re-plugged it in a whammo it now locks...
the rear hatch I do not understand could there be a fuse for it someplace that is not mentioned??? I took all the working parts as in the popper itself which has two plugs and the wiper motor that says open glass on it from my other limited and swapped them. It still doesnt work on the Green Jeep and the Red jeep still works fine I dont see any broken wires anyplace anything unplugged any help would be greatly appreciated
Rob
1996 Jeep Grand Cherokee Limited (2 of em)
