Driver's door lower hinge replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Driver's door lower hinge replacement
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineXJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!
Unread 01-13-2005, 11:09 PM   #1
josephmartins
josephmartins's Avatar
I did some Googling and came up empty-handed. Any suggestions for a retailer that sells the lower hinge assembly? Or am I stuck going to the factory for this one?
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8 conversion, <10 miles (FOR SALE, $56,700)
01 WJ Limited, 4.7, 247, black on black, 157k miles (sold)
96 XJ Classic, 4.0, 242, black on grey, 267k miles (sold)
00 XJ Sport, 4.0, 242, fern green on grey, 76k miles (sold)
90 XJ Wagoneer, 4.0, 242, burgundy on tan, unknown mileage (sold)
97 ZJ Limited, 5.2, 249, black on black, 138k miles (wrecked 12/15/05)
98 ZJ Limited, 5.2, 249, burgundy on black, 197k miles (sold)
josephmartins is offline   Reply With Quote
Unread 01-13-2005, 11:14 PM   #2
josephmartins
Warren are these parts numbers valid for a 97 as well? I saw them in one of your older posts regarding a 96 ZJ:
Pin, Hinge 5507 6192 (2 per door)
Bushing, Hinge Pin 5507 4591 (4 per door)
Thanks in advance.
Kind regards,
Joe Martins
Milford, NH
Unread 01-14-2005, 09:17 AM   #3
oct7brian
Have you tried partstrain.com I get part from them every once in a while for vehicle I'm working on. Not sure on the hinge but I would check it out
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline   Reply With Quote
Unread 01-14-2005, 09:30 AM   #4
rowdy1
Door Hinge
If you have a buddy who runs a body shop,he can get you this part with no problem. That's how I get ALL my stuff
rowdy1 02 GC Laredo
rowdy1 is offline   Reply With Quote
Unread 01-15-2005, 12:01 AM   #5
josephmartins
Great idea rowdy. Hey Brian, thank you as well. I did check that site but they don't seem to carry that particular part. Looks like I'm off to talk to a body shop.
Kind regards,
Joe Martins
Milford, NH
Unread 01-15-2005, 08:53 AM   #6
Stocker
I believe the pins and bushings are dealer items only; why not just buy them yourself and avoid the body shop's mark-up? Nick (Kolak@aol.com) will likely sell them at a discount, and he will know if the parts are the same for your '97.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline   Reply With Quote
Unread 01-16-2005, 01:55 PM   #7
josephmartins
damn, good point, I should've just asked Nick when I place my order last week. thanks for the reminder.
Kind regards,
Joe Martins
Milford, NH
Unread 01-16-2005, 09:00 PM   #8
frytzz
I just did this a month ago. I bought them from a local dealership for 12 bucks a set. It was actually a pretty easy job. I am tool challenged. So if you can get a friend to help it's pretty easy. You need to remove the wiring harness. There's one little hex screw in there, then the whole harness comes lose. Then just remove the bolts and take the door off. We then used a dremmal and ground the old bolt at both ends. It took about an hour or so. It's pretty simple. The guy you mentioned wanted 35 bucks a set.
Hope that helps
Brian
frytzz is offline   Reply With Quote
Unread 01-17-2005, 06:47 AM   #9
Stocker
Originally Posted by frytzz
So if you can get a friend to help it's pretty easy. You need to remove the wiring harness. Then just remove the bolts and take the door off.
I'm not questioning this method, but I did mine by myself without removing the door (or the wiring). Just support the door while the pin is out. And I only ground off the top of the pin, then drove it out downward.
Stocker
Unread 01-17-2005, 09:34 AM   #10
frytzz
it's a very tight fit without removing anything.
Unread 01-17-2005, 10:11 AM   #11
Meerkat
Thanks in advance.
Joe, Sorry I missed this post..
The part numbers are going to be the same, however, they may have been superceded. The counter guy will find that out when he looks up the old number...
We have a guy that posts on here every now and then that is a parts guy at a Jeep dealership in Charleston, SC. If you contact him, he may be able to discount your parts pretty heavily. PM, email JOEL@MPSC, or call 1-800-456-5337 and ask for Joel.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote
Unread 01-17-2005, 02:13 PM   #12
josephmartins
Frytzz-
$12 per set? Wow...where the heck did you buy them at that price if you don't mind me asking?
Warren -
Thanks for the info. Your part numbers are still valid. I called Joel as you had suggested. He was very pleasant to deal with and very helpful by the way. Here's what I got:
Pin, Hinge 5507 6192 (2 per door) $4.03 each
Bushing, Hinge Pin 5507 4591 (4 per door) $2.86 each
So for a complete set we're talking $19.50 plus shipping/handling of $6.00 minimum. Joel's company's website is:
http://www.moparsupercenter.com/
And he says you just order online and insert the information above when ordering. The order form can be found HERE .
Having said that, I already ordered from Nick [Kolak] yesterday for $40.00 shipped. I could have saved $15.00. But Nick has been such an enormous help with finding the right parts for my rig that I'd say he's been invaluable to me - much like the members of this forum. So $15 is a small price to pay. And (hint hint to new Jeep Forum members) $25 is incredibly reasonable for dues to this invaluable Jeep Forum.
Kind regards,
Joe Martins
Milford, NH
Unread 01-17-2005, 03:32 PM   #13
frytzz
Fred martin
330753444
I called and they had them in stock. 8.12 for pin and 5.76 for the bushing and they will ship.
Hope that helps
Brian
