Driver side blend door actuator problem - JeepForum.com
post #1 of 1 Old 11-04-2009, 08:47 PM Thread Starter
thumpr77
I have a 99 grand cherokee ltd and after much research online finally found the time to investigate my blend door problem. I found that the driver side actuator does not move when I adjust the temperature up and down. I then checked the voltage and found that it was showing 9.3 volts on and off rapidly. My question is, is this voltage reading normal? I want to confirm the problem lies with the motor and not the voltage going to it, any suggestions? I have temporarily opened the atuator casing and rotated the gear to hold blend door fully open to allow heat on drivers side, but would like to properly fix the problem.
Thanks
thumpr77 is offline
Blend door issue but not door, actuator or control panel. What else could it be? TGMInd WJ Grand Cherokee Forum 37 12-19-2014 08:12 PM
WJ Passenger Side Blend Door Actuator thisguyhasadd2 ZJ Grand Cherokee Forum 34 01-21-2009 07:46 AM
Blend Door Actuator? ScotAusborn ZJ Grand Cherokee Forum 26 08-24-2007 06:10 PM
ZJ Blend Door Actuator twmattox ZJ Grand Cherokee Forum 1 07-16-2006 05:05 AM
Blend door actuator motors vendsit ZJ Grand Cherokee Forum 0 05-25-2006 09:20 AM
