Driver's door triggering alarm - JeepForum.com
post #1 of 8 Old 01-22-2004, 06:45 PM Thread Starter
kornholio
Hi,
I lock the doors on my 95 Grand Cherokee Ltd by using the power door lock switch. When I go to unlock the driver side door with my key, it triggers the factory alarm. When I unlock the passenger side door with the key, it disarms the alarm. It is a hassle to unlock the doors by going to the passenger side first.
Does anyone know what would cause this? Is there a way to disable the factory alarm completely?
I haven't had a chance to take the drivers door panel off to check the wiring, as it has been too cold outside.
Thanks.
kornholio is offline
post #2 of 8 Old 04-04-2004, 11:02 PM
elsmooth
Try checking the switch key wire that is connected to the back of the key cylinder. It probably has come off.
elsmooth is offline
post #3 of 8 Old 04-05-2004, 06:29 AM
gthaefner
Look in the doorjam at the big rubber thing that takes the wires from the body to the door, kinda push the thing down and see if any wires are showing. It should be a black one
94 ZJ
4.0 I6
NP242 swap
3.5 RE superflex with adj. arms
adj. trac bars
31s for Now
LOWERED CARS ARE FOR PEOPLE WHO CANT GET IT UP
gthaefner is offline
post #4 of 8 Old 04-05-2004, 10:32 AM
elsmooth
Are you saying that the black wire is the one that disconnects the alarm?
elsmooth is offline
post #5 of 8 Old 12-27-2013, 12:57 PM
jeells
Did you ever figure out this problem? My 98 is having the same issues
jeells is offline
post #6 of 8 Old 12-27-2013, 01:39 PM
kensnelling
Don't expect an answer from those guys, they haven't been on in years.
Did you check the possible causes for the problem that were listed? If not, do that. Those are the 2 most likely causes of the problem you say you have. The switch on the back of the lock cylinder is most likely the problem.
Ken
kensnelling is offline
post #7 of 8 Old 12-27-2013, 03:11 PM
durango-bob
2006 WK
As Ken stated, the problem is that the switch on the back of the door's key switch is not working anymore. There is a deactivation switch on each one of the key locks, so you can use any of them to disarm the alarm. It will also disarm with the remote. It is activated with the remote or with the power lock switch when the key it out of the ignition and the door is open.
durango-bob is offline
post #8 of 8 Old 12-27-2013, 05:24 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
They, at this age, are incredibly easy to break also. They run about $40 from mopar if they are still available. If you get one out of a JY use care in removing it, pops off the back of the cylinder. A triangular shaped spring wire holds it on to the back of the cylinder.
Originally Posted by HighLonesome
coralman is offline
getting driver's door window out alexsious ZJ Grand Cherokee Forum 3 04-04-2009 04:33 PM
driver's door sensor?? CMARJEEP ZJ Grand Cherokee Forum 18 02-09-2009 01:24 PM
Alarm doesn't work when driver's door is slammed shut martingsa ZJ Grand Cherokee Forum 2 01-30-2009 04:16 PM
Driver's Door Hinge 2007GrandDiesel WK Grand Cherokee & XK Commander Forum 4 02-14-2008 12:18 PM
Driver's Door Lock Izzy ZJ Grand Cherokee Forum 7 07-31-2007 01:21 AM
