Driver Door Module or Body Control Module - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Driver Door Module or Body Control Module
D.i.y. Ford 8.8 tj,xj,yjTrek Armor Seat Covers now at JeepHutJeep Restorations, Mild to Wild! CCOR
Unread 04-05-2008, 10:42 AM   #1
ronmaynard
2004 Gr Cherokee. Driver door power windows/locks/mirrors do not work. Interior light has to be turned off manually. Passenger door controls are fine.
Half of the forums point to the BCM and the other half say its the DDM. The door ajar indicator is OFF so its not the latch.
Both parts are expensive so I want to test to verify which one it is before I order.
Any help is greatly appreciated.
ronmaynard is offline   Reply With Quote
Unread 04-05-2008, 05:59 PM   #2
merlinTec
Hi
First place to start is checking the wires from the door to the body where it bends with the door, very common for the wiring to break.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline   Reply With Quote
Unread 04-05-2008, 07:21 PM   #3
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I had the same thing on an XJ. I changed the door control, @ $245, and it did not fix it. Found a broken wire in the rubber boot from the drivers door to the body.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
www.militaryjeepers.com lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline   Reply With Quote
Unread 04-28-2008, 08:13 AM   #4
ronmaynard
It's fixed - broken wire
Thanx much for the tip. It took me a while to get around to fixing it but there was 1 broken wire, i believe the ground, in the boot between the door and the body. There was also another with 2 cracks in the shielding. I will probably have to replace the wiring harness eventually, but at least its not the control modules.
Time to fix, 10 minutes. Cost $0!!!!
