Driveline Rumble - JeepForum.com
post #1 of 2 Old 08-23-2010, 02:25 PM Thread Starter
BilletHorse
Driveline Rumble
I have a vibration (rumble) in the front driveline (of my 1995 Grand Cherokee) that I can't track down. I had a new front driveshaft made (with all new CV parts and yokes) because the old CV joint took a dump. Before it did, it shook the driveline pretty good. I put the new shaft in, but still have a vibration, especially when I first get on the freeway. If I put the select-trac in full time loading the front driveline, the vibration goes away for the most part. I just pulled the shaft again to check the front diff yoke and transfer case yokes for tightness, and they are. There is a small amount of side play in the t-case bearing, and it is losing oil somewhere (hard to tell).
Could the t-case output shaft bearing be shot or the case itself, or anything else to look for?
With the driveline out it's as smooth as glass.
BilletHorse is offline
post #2 of 2 Old 08-23-2010, 03:30 PM
sandman
if there is play in the front t-case output that is most likley your problem, could be the source of your leak too.
1993 Jeep ZJ. 4.0
sandman is offline
Rumble, vibration in rear end?? Gerald K4NHN ZJ Grand Cherokee Forum 2 12-02-2007 10:40 AM
Rumble/vibration at highway speeds Little Black ZJ ZJ Grand Cherokee Forum 4 09-09-2007 04:18 PM
Rear End Rumble barrowjeep ZJ Grand Cherokee Forum 4 02-20-2007 04:36 PM
Rumble from drivetrain? DTom ZJ Grand Cherokee Forum 2 12-03-2005 05:24 PM
Vibration (Rumble) only under acceleration Deanwa ZJ Grand Cherokee Forum 4 08-24-2004 08:58 PM
